So how do YOU change wheel studs?
LS1Tech Co-Founder
Re: So how do YOU change wheel studs?
I just remove the wheel and hammer them out. Use a centerpunch if it is broken down to the base.
The fronts are easy. The rears have a little dished area inside the E-brake housing that you line up with the empty hole to stick a new stud in.
Tony
Tony
I stripped two out on my Moser and pulled the axle and took it down to a shop to have them pressed out. They looked at me like I was crazy. We ended up just hitting them with a hammer to knock them out and used a lug to pull the new ones in. Oh well, live and learn <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Mark
Mark
Yep, I changed one out on the front this morning, and I just whacked the crap out of it with a hammer and chisel. I then loaded a few washers on, threw a lugnut on, and pulled it in. It's good as new. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I tried bashing my fronts out with a BFH! to no avail. Even soaked them in wd40 for a few hours for some slippage help...nothing. The tips of the studs start to mash without even budging. ARGH!
Looks like I have to get them pressed out. Oh well prolly will cost hardly anything to do anyway.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSpeed:
<strong>I tried bashing my fronts out with a BFH! to no avail. Even soaked them in wd40 for a few hours for some slippage help...nothing. The tips of the studs start to mash without even budging. ARGH!
Looks like I have to get them pressed out. Oh well prolly will cost hardly anything to do anyway.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you have a torch even a propane torch heat them up this will brake them loose.
Wheels up Director
If you don't have any washers laying around just turn your stock lug nuts around and that'll do the trick, I was told to add a little anti-seize to the knurl, took about 5 minutes per hub to seat all the studs
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
When I stripped 3 on the rears, I took it to two places and the problem was that they were too long by a hair to be pulled out. They would've needed to pull the axle.
Luckily, the new ones were a few mm shorter and fit in perfectly, so they cut the old ones out. That's $150 I never wanna have to spend again!
Nick
Nick
