The Best Rotor / Pad Combo ?
Old 08-03-2007, 08:42 AM
b.lee's Avatar
Default The Best Rotor / Pad Combo ?
I'm in need of pads and rotors for the front of my car.
Definitely not getting stock or autozone parts.
Looking for a drill and or slotted rotor... which ever is better.
Also looking for good pads that don't make tons of dust.... if possible.
Let me know what you guys recommend for a rotor/pad combo for the front...
I'm not interested in anything thats going to cost an arm and a leg.
But i don't want to get the cheap-o version either.
Thanks.
Old 08-03-2007, 01:28 PM
Hennytime's Avatar
ws6 store rotors and hp hawk pads, they are like 300 all said and done on all 4 corners
Old 08-03-2007, 03:10 PM
Reznor's Avatar
pretty much anything is better than stock for boltons. i went with irotors (slotted and cross-drilled) on all 4 and hawk pads.
but now that i'm cammed and making more power, i think i need new calipers with more pistons and bigger rotors.
Old 08-03-2007, 04:54 PM
Greggy's Avatar
if you want less dust don not get hawk HP.
Get Hawk Ceramics (lowest dust) or HPS (light dust).
Duralast Rotor work just fine. Drilled or slotted rotor will not help you stop better and can create other problems.
Old 08-03-2007, 11:11 PM
SScott's Avatar
With modern brake pad materials you don't need the venting. Drilling will lead to rotor cracking in racing, they are ok for the street but for looks only.
Old 08-04-2007, 01:24 AM
kaos_'s Avatar
i'm using baer eradispeed rotors and hawk pads. the brake response feels great. although i'm pretty sure it's just the pads i'm noticing as i didn't feel any difference upgrading to slotted/drilled rotors during daily driving.
Old 08-04-2007, 10:07 PM
SScott's Avatar
Oh and stainless steel braided brake lines, and good dot4 brake fluid will help out a lot also.
Old 08-04-2007, 10:43 PM
greg_74's Avatar
Same here except HPS Hawk pads instead of HP pads.
Old 08-04-2007, 10:48 PM
Trunion King
bene's Avatar
I'm using brembo blanks/hawk pads, ATE superblue brake fluid. They are all relatively cheap. No more spongy brake feel.
Old 08-05-2007, 01:19 AM
kaos_'s Avatar
how do the steel brake lines feel over the stock ones? is it worth it to upgrade?
Old 08-05-2007, 10:07 AM
SScott's Avatar
in a word YES
Old 08-05-2007, 10:37 AM
Moderator
davered00ss's Avatar
I just bought those. If cost was not an issue, I would get willwood or SSBC.
