whats the general opinion on brembo rotors?
Old 10-18-2007, 07:13 PM
Wolfwoodx89's Avatar
Default whats the general opinion on brembo rotors?
my rotors are really gettin worn down so i figure i may as well get something better. Ive been looking and i was wondering whats the general opinion on brembo crossdrilled rotors. I know its a stupid reason to buy a certain brake, but i also love the way crossdrilled rotors look on cars to.
Old 10-19-2007, 01:34 AM
peterlawl84's Avatar
I was going to get Brembos on my car a few years ago, but was told by the owner of the shop that Baer's were pretty much the same but far less. (I like the cross-drilled look as well) So I went with them and have had them on my car for 2-3 yrs now and haven't had a problem. I love them, they stop way better than previous rotors I had. I warped the stock ones a long time ago, then tried powerslots...those worked for maybe a year and got warped. Just my 2 cents.
Old 10-19-2007, 10:36 AM
OldeSkool's Avatar
Brembo blanks are the best replacement for the stock rotors IMO
Old 10-19-2007, 01:41 PM
z28bryan's Avatar
Are you thinking about getting a whole brembo brake kit including calipers? I'm trying to figure out why you are asking the question and that's what I'm guessing you were thinking. If you were, you can get crossdrilled rotors on the stock brakes.
Before buying them, check out the brake sticky. I wouldn't ever use cross drilled rotors on my current car because they don't really help for performance reasons with normal brakepads, but I'm also not going for looks like other people who like the cross drilled/slots. I live with my rusty brembo blanks because they are durable for what I do
Old 10-19-2007, 01:52 PM
OldeSkool's Avatar
ditto on the crosdrilling... doesnt help stopping, just makes the rotor fragile and increases pad wear.
Old 10-19-2007, 03:20 PM
02Z28LS1's Avatar
if you're replacing only the rotors (and not going with a full brake kit), then just get some Brembo blanks & be done with it. they usually resist warping a lot better than some AutoZone replacements, as long as you take the time to "bed" the pads properly and take it easy on hard braking for the first 100 - 200 miles
Old 10-19-2007, 03:25 PM
robertbartsch's Avatar
Are the non-drilled, non-slotted Brembo rotors lighter in weight than others?
Old 10-19-2007, 04:53 PM
i was just trying to get just new rotors to replace stock ones. But after reading everything here i gotta ask, is there a really huge difference in the wear down of the rotors between cross drilled and blanks? I mean i already assumed the drilled ones would last less because its kinda common sense since theres less rotor there, but Im going for looks on this car for the next year and a half or so until i got the money to do some serious motor work. If crossdrilled have a very noticable decrease in life compared to blanks, then i guess i can sacrifice the awesome look of crossdrilled for a better product, but if the life isnt that far apart, then i'll probably go with drilled anyway.
Old 10-19-2007, 05:58 PM
OldeSkool's Avatar
Too hard to quantify. I have smooth rotors and have had the same pads for 45,000 miles and there's still plenty of meat on them. I heard a guy a few weeks ago that changed his pads 3 times in just as many miles with drilled rotors. But that doesn't necessarily mean 3 times the pad wear. He was probably using different pads and he may be 3 times as hard on his brakes as I am.
But still, are you buying something that you depend on to save your life based on how it looks?
Besides that, drilled rotors just kinda look ricer-ish to me. But thats just my opinion.
Old 10-19-2007, 11:42 PM
02Z28LS1's Avatar
this discussion has come up many, many, many times in the past, and there's not really any new information that would lead someone to come to a different conclusion.
you're not really going to notice much actual wear on the rotor itself, unless something happens to get wedged in between the pad and the rotor and gouge into it (which, ironically, would happen a lot easier on a drilled/slotted rotor).
the main thing here is that the drilled and/or slotted rotors are going to eat away at your brake pads a lot quicker, due to the non-smooth edges....kinda like putting your pads through an electric cheese grater. also, you have to worry about the rotors cracking when they are slotted/drilled. since it is an uneven surface, the edges of the drilled holes/milled slots are going to cause little "hot spots", which can lead to the rotors cracking. in most cases, the cracks are mostly cosmetic, but there is always the chance that it can later lead to a catastrophic failure, where the rotor breaks into separate pieces. after all, what happens when you heat something up a lot, then cool it down very rapidly (such as running them through a puddle of water)? if there are hairline cracks, it may be just enough to cause it to fail.
even brake manufacturers have notices on their pages that drilling/slotting rotors doesn't really help for a street-driven car. see Baer's FAQ page and read the second question/answer.
so once again, for a street-driven, non-race car, just get some quality "blank" rotors like the Brembo blanks i mentioned earlier....the Brembo blanks will resist warping a lot longer than cheap AutoZone replacements
if you're looking to improve the looks, just put on some good blanks, leave them on for a couple hundred miles, then remove them again and paint the "hats" of the rotors (the part in the center that doesn't contact the brake pads) with some high-temp engine enamel, then do the same thing to the calipers.
Old 10-20-2007, 12:02 AM
z28bryan's Avatar
If I were building up a garaged car or show car, I'd probably get something that doesn't rust at least. Some rotors have special finishes. Cross drilled rotors aren't going to kill you, lots of people run them with no problems
Old 10-21-2007, 05:55 PM
alright well after a lot of thougth i think ive decided to get the c5 brakes conversion that is unless people have had bad experiences with them. But what iw as wondering is whats the difference between
http://www.ws6project.com/user_stor/...48a738e1ef5236
and
they look the same to me but im curious why ones 200 cheaper. does the UMI name really mean that much even if its just the title?
Old 10-23-2007, 09:48 AM
UMI Performance's Avatar
and
Your links are broken, but I assume its because one kit has different rotors? Either way whether you purchase a "UMI" brand kit or a "WS6Store" brand kit you are still getting the high quality UMI conversion brackets built by us. Either kit will be a excellent choice!
Hope that helps!
Ryan
Old 10-23-2007, 01:27 PM
loyolacub68's Avatar
Mike at RotorsOnline got me hooked up with my set of Brembo blanks and it was the cheapest out of any sponsor.
Old 10-24-2007, 12:44 PM
Brembo cast iron casting are superior. They are made in left and right components and the fins beween the inner and outer rotor are slanted and are designed to channel air in and to cool the unit.
Other rotors are usuallly not front/right specific and tend to not channel air at all.
All-in-all these are great. get the non-drilled, non-slotted versons for the very best performance.
Old 10-24-2007, 07:40 PM
camar0corey's Avatar
For as many looks people took at my Baer cross drilled and slotted you'd think I woulda kept mine. I had such rotors crack, so even though they looked badass, brembo blanks took their place.
Quick Reply: whats the general opinion on brembo rotors?
