unsure on if i need all this
Old 10-19-2007, 02:24 PM
transamfreak01's Avatar
Default unsure on if i need all this
i am getting ready to mess with the suspension and i was told by a company i would need all of this but i dont think that i do.
tubular adj. lcas w/ relocation brackets
complete a-arm set up (chrome moly)
tubular k-member
tubular single adj. panhard bar
3 point subframe connectors weld in
tunnel brace mounted torque arm (chrome moly)
qa1 f series adj shocks and springs
the car is a street car and will only see the track maybe 4 times a year. thanks
Old 10-19-2007, 02:49 PM
z28bryan's Avatar
You don't really need any of it to put your car on the track. Some of those things will improve your performance and some of those things you will be spending more dollar per benefit. Each of those modifications will have their pros and cons effecting the way the car will handle.
I'd just take your car to the track as is and find out what your car does that could need improvement on. Analyze your situation and then buy modifications to fix any problems you have.
Old 10-19-2007, 02:57 PM
robertbartsch's Avatar
A arms, sub-frames, torques arms, K-members, and LCAs don't do much for handling, if that is what you are looking to improve.
Get some good shocks and sway bars. They will do wonders.
Talk with Sam Strano who can help you decide what to get based on what you expect to improve over the stock factory set up.
Old 10-19-2007, 03:03 PM
z28bryan's Avatar
Depends on what track he wants to go to? Road racing? 1/4 mile?
A tubular Kmember is mostly used to shed weight and make engine bay access easier. Tubular frames have had durability issues in performance situations. UMI has a new road race kmember which is slightly heavier but still lighter than the stock one and is supposed to be good enough for high performance applications. The front control arms I think help shed a little more weight and most allow camber adjustability which is useless for drag racing I would think. That's like a ~1000 dollar package to shed some front end weight. Question of how much are you willing to spend for what benefit?
Old 10-19-2007, 06:06 PM
OldeSkool's Avatar
bang for buck parts I'd recommend
Drag Racing:
Full length torque arm with relocation crossmember
Poly/Rod lower control arms
A 12 bolt or 9" rear axle with some big fat drag slicks
Road Racing/ Autocross/ Back Roads and Daily Driving
Koni Shocks
Strano Springs and Swaybars
Wheels and tires (if not already sufficient)
Poly/Rod or Rod/Rod panhard bar
and then maybe
Torque arm and Relocation Crossmember
Poly/rod LCAs
Old 10-19-2007, 06:40 PM
sorry about that... the car is only going to be for 1/4 mile on the track and street. but yeh i didnt think that i needed all that crap that they said
Old 10-19-2007, 07:28 PM
Moderator
jimmyblue's Avatar
tubular adj. lcas w/ relocation brackets -
adjustable only if non-stock rear or frame damage. Relos only
if lowered.
complete a-arm set up (chrome moly) -
No
tubular k-member -
maybe, kind of expensive way to go about weight reduction, if
you do it get a "road race" and street tough one.
tubular single adj. panhard bar -
yeah, OK, but only if you don't like the stock bar's centering of
your axle presently. It could probably wait.
3 point subframe connectors weld in -
add weight, no general agreement whether they help more than
psychologically. Call it "maybe".
tunnel brace mounted torque arm (chrome moly) -
only if you're hard over on drag launch suspension mods and like
a shitload of cabin noise.
qa1 f series adj shocks and springs -
drag, maybe; street / AX / road race, plenty of better options
Old 10-19-2007, 07:29 PM
RE AND CHERYL's Avatar
Suspension wise I would recomend (besides your favorite springs and shocks) Subframe connectors, LCA relocation brackets, and an adjustable tourque arm.
Re'
Old 10-20-2007, 12:17 AM
coolformula's Avatar
This question is very board.
I would say Konis/Sam springs and dual rod end panhard bar(does wondors for DD and handling) will be mean on the street and twistys and still lauch fine. If your have wheel hop etc you need to address them issues.
Old 10-20-2007, 01:47 AM
OldeSkool's Avatar
if lowered.
No
tubular k-member -
I agree with this post with the exception of the LCA's.. non-adjustable is typically synonymous with poly/poly which is not a good way to go for a street driven car, poly/rod is a better choice as it virtually eliminates suspension bind, it offers even less deflection without transmiting much more noise. Though adjustability on its own isnt needed unless your rear thrust angle is significantly off, its just a by product of the rod end.
Old 10-20-2007, 08:35 PM
[QUOTE=coolformula;7978885]This question is very board.QUOTE]
i guess what i am asking is what is reccommended for a street car that will see the 1/4 mile track a few times a year but will mostly only be used on the street, has some wheel hop, isnt lowered at all and is looking for more traction mostly....
hope that helps some
Old 10-20-2007, 10:18 PM
Sunset'01Z's Avatar
first get better tires, mt dr's or simliair, then get some suspension mods. i have poly/poly lca's, they helped alot with wheel hop in my car. i still have the stock torque arm, hopefully will be buying a full length tubular one soon to get rid of the rest of my wheel hop and low speed traction problems.
Old 10-21-2007, 05:57 PM
chrismorales75's Avatar
First I would get a set of drag radials.
I would get a drag style rear anti roll bar and front and rear adjustable shocks.
If you still care about handling I would get a double adjustable front and single adjustable rear.
If not you can run the QA1 "r" drag valved single adjustable front and single adjustable rear.
If you have wheel hop you could use relocation brackets, to save money you can box the LCA's and panhard rod.
Later once you go faster I would look into a non-trans mounted torque arm set up.
As far as subframes you can install those whenever, but I would install them and use outriggers before you put in a cage.
The k-member and a-arms are not a real need until you get serious about your car going fast and feel the need to spend a lot of extra money to go a little faster.
Front and rear springs will help 1/4 stuff, it's all a trade off for street handling, personally I don't try to go around corners really fast, so I run 275# in front 150# in rear and doesn't bother me a bit since I am use to it.
You can also bypass the power steering pulley with a shorter belt at the track to gain a little power.
Old 10-21-2007, 06:05 PM
z28bryan's Avatar
Get the lca relo brackets, probably the poly/rod ctrl arms to help out with the wheel hop problem. I would seriously look into other options before buying the QA1 shocks though.
Koni's might be a good shock choice actually, but I don't know about suggesting Sam's springs for this. In drag racing you want the front end to lift and stock springs would be a better choice for that.
Old 10-22-2007, 01:50 AM
the car has mt et street radials on it so im fine there.... what type of shocks and springs are you guys running
Quick Reply: unsure on if i need all this
