HAL Generation "F" Series Shocks Front & Rear Shock + BMR lowering springs???
What are your thoughts on this setup:
HAL Generation "F" Series Shocks Front & Rear Shocks (86-PKG-2) + BMR rear lowering springs???
I was thinking of getting the 275 spring so I'll have great track performance. How much will it limit street driving?
Yes, I want the best of both worlds (to be lowered and have great 60 fts)
First I would get the *R*series fronts, either QA1's or Strange. Instead of buying QA1 springs buy the BMR spring cups so you can run your stock springs. The 275# springs are WAY too low, and IMO a bit soft for heavy cars like ours. With the QA1's/Strange front shocks you can adjust the ride height, and just run your stock springs. For rear springs, I think the BMR's would be fine as would any other rear lowering spring. Or you could just cut the stock rear springs to get the desired height, thats what I did as well as many others.
Awesome...thanks for the info.
So for the front you'd recommend getting 2 of "R" series part number: 86-RC-7855-P
What about for the rear shocks? Two of these: 86-TC-2501-P?
STR-S5269(front), STR-S5270(rears). You would still need to get BMR spring cups, which you cannot get from SJM. Also you can buy a set of torrington bearings, which will make adjusting the ride height easier.
http://www.sjmmanufacturing.com/cam_sus_ls1.html#
For the BMR spring cups, you only need to order 1 set of (2) cups. Just for the front. The rears are not a coilover design, so for them you just go ahead and bolt them in and adjust them.
