You ever hear this noise...?
99% of my rear suspension on my car has been changed out to new stuff and I am pretty sure it is not coming from the rear of the car but sometimes when I hit a nice bump in the road like a speed bump going thru the parking lot, I hear a sound from the area under the passenger side seat, it sounds like a cross member or something hitting under that side of the car...anyone else have this or ever hear this type of noise? I need to get my car on a lift and get under there to check it out....
I hear the same sound when the suspension bottoms out, or is close to bottoming. If is almost like someone hit the rear passanger frame rail with a 15Lb rubber mallet...
Todd,
Since you have our SFC's try to re-torque the rear control arm bolts. This sound is common once SFC's are installed that attach at the rear control arm mount. The mount requires much more pressure to compress the bushing with the SFC's installed. Trying tightening them more, up to 100 ft. lbs.
Hope that helps!
Ryan
Hope that helps!
Ryan
Thanks for the suggestion UMI Performance...
Does this happen because the Subframes that I have welded to the rear LCA mounts are trying to bend the sheet metal away from the LCA, making a big gap and alowing them to move and clunk?
