How often should you realistically bleed your brakes?
Old 07-24-2003, 05:41 PM
SStolen's Avatar
Default How often should you realistically bleed your brakes?
Doing my brakes and wondering whether those Earl's Brake Bleeders are worth it since I can't always find someone to hit the brakes for me. They are only $32. Thanks -Mike W.
Old 07-24-2003, 06:42 PM
trackbird's Avatar
Default Re: How often should you realistically bleed your brakes?
Speed bleeders are a great idea. Even if you still bleed normally (open and close the valve), it helps keep air out, no matter what. It is a habit for me to bleed by opeining and closing the bleeder, but either way, they are worth the money.
I usually bleed the brakes every 6 months or before events, whichever comes first.
Old 07-24-2003, 10:23 PM
Diesel's Avatar
Same here!
Old 07-25-2003, 01:34 AM
SStolen's Avatar
What kind of brake fluid should I use and should I flush it out and if so, how? Doesn't brake fluid break down after so long? The car has 36k and it is pretty dark. I'm doing my cam swap very soon so that might make it easier since I can dump the resevouir(sp?) out. Thanks.
Old 07-25-2003, 02:39 AM
LS1 Brent's Avatar
How do you bleed the brakes and why do you have to do it?
Old 07-25-2003, 04:29 AM
Diesel's Avatar
I used a compressor & vacuum tool to bleed the brakes. Brake fluid is Hygroscopic and tends to attract moisture. When enough moisture/water builds up it compresses giving the brake pedal a spongy feel. Additionally, you want to bleed the brakes to remove any sediment in the fluid.
Old 07-25-2003, 04:31 AM
Diesel's Avatar
I went with ATE Superblue, but I've heard good things about Motul & Castol SRF as well. SRF is kinda pricey though. LGM carries Motul & SRF I think....
Old 07-25-2003, 05:01 AM
DaddySS's Avatar
Bleeding the brakes is important primarily to get the moisture out of the system and prevent rust in the lines and calipers. Once every two years is OK, once a year is better.
Use any high quality high temp fluid made for disc brakes.
Old 07-25-2003, 05:54 AM
mitchntx's Avatar
My routine was to run a bottle of Motul 5.1 through the system before each road course event and a whole system flush once a year. That got to be pricey and a PITA.
I switched to Castrol SRF last fall and have bled the brakes one time since. So, for me, it was justifiable.
The thing about brake fluid, is that it has a very short shelf life. It loses ANY shelf life once you break the seal on the bottle.
So, if you decide to bleed the brakes, go ahead and use up the entire bottle.
For a street car, once a year should be fine and friends of mine had great things to say about Valvoline brake fluid. Comes in a quart bottle which kind of gold in color. This is the stuff I use in my tow truck and my wife's Bronco and my duaghter's Honda.
Old 07-25-2003, 07:18 AM
trackbird's Avatar
I've been using up my cans of Ford Dot 3 (the stuff in actual cans that was good fluid that stays fresh). I am starting to use ATE super blue. ($9.99 a can from www.ogracing.com and others).
Old 07-25-2003, 11:37 AM
talonis's Avatar
How much fluid do you guys use during a typical flush? And with regard to the SRF, I've read that you can't mix it with other fluids. So how did you bleed the brakes without mixing it?
Old 07-25-2003, 12:21 PM
Diesel's Avatar
Bleed each caliper till the fluid changes color completely, then bleed it a little more.
Quick Reply: How often should you realistically bleed your brakes?
