why is my gf's 98 honda ride smoother than mine??
I got new koni's and the prokit couple months back and everytime I drive my girls 98 accord it feels way much smoother and I don't feel and bump in the road. With my new setup I is a major improvement but I still feel it rough in some parts of the streets/road..
You're comparing apples to oranges. Good luck trying to get the 4th gen to ride as well as a Honda Accord. Accords are awesome daily driver cars and have great suspension setups for ride comfort compared to other cars, as well as their seat quality and position. They don't handle nearly as well though. Something has to give. Some cars are great at doing both, such as a BMW but you pay a hefty price for the best of both worlds.
My gf's Hyundai Elantra however, I was quite relieved to get into my Camaro with upgraded suspension after a vacation in the Hyundai. The Elantra's suspension is "pretty good" for ride quality but it's seat quality and position isn't. I also hate how I can't rest my right foot on the pedal without flooring it, while the Camaro comfortably supports the weight of my foot resting. I feel like I'm working to hold my foot up for the multi hour trip, which sucks.
bigger car different chssis plus u have tttops less rigidity, get some subframe connectors and a strut tower bar and it will be as smooth as rough glass lol....but seriously with subframe connectors and st bar u will seriously stiffen up plus the i am not a fan of the eibachs crappy ride quality, i run hotchkis and love them...good luk
yea I'm thinking of going a different route from the prokit. I love the stance but seems to soft Here we go again changing crap but I will be doing the install this time. Got some tools now and I've seen the shops twice do the install and it doesn't seem too bad.
what springs would fit well with the koni's?? want it lowered too
I love driving the gf honda
I didn't notice anything with my STB, and many don't notice a difference with SFCs. And the ones that do notice a difference say the car rides worse than before (more jarring).
BTW what is your tire pressure set at?
if you were concerned with ride quality, why in the world did you get a performance lowering spring?
use the stock springs, put the konis on the lower perch and do the hose mod.
but seriously, you can't have extreme handling and luxury ride, you have to make some compromises, even BMWs do.
Bilstein is better for ride quality than koni, but you can't use lowering springs with them.
LS1TECH Sponsor
I agree it's apples and oranges.
You can't compare a car with a solid rear axle, lowering springs, performance shocks, more performance oriented tires to a Honda Accord that's whole reason for being is for a nice ride.
If you want a better ride, first thing to do is go back to stock springs which are taller and softer, and keep you Koni's in place for the damping control. The Pro-kits aren't doing you any favors with their combo of height and spring rate. A better lowering spring would help, but if ride is such a big concern the best ride will come from the longest spring travel and lowest rates you can get to support the height. The GM springs are that choice.
In the end, it's completely unrealistic for you to expect Accord ride quailty, but you can get a lot closer than you currently are.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Well, for Christ Sake Man. Don't they teach you kids anything in school? We kicked what countries *** in WW2? Japan silly!!! Why, you hopefully ask? Because they are soft, today, they were soft back then. The ride of their cars is soft..
I do have a question. Why does your GF drive that car? You can control this stuff you know! Scares me man, you let your GF drive a what? Why!
Jakes Dad
Jakes Dad
Likewise, some American family cars have a fairly smooth ride too (Chevy Malibu etc.)
The objective of the Honda Accord (and many other family sedans) is to provide an efficient, comfortable car at a fairly affordable price. What is the objective of the F-body? Understand this and you'll soon stop worrying about the ride quality of your car.
Jakes Dad
Jakes Dad
a bunch of domasses on here were touting that konis would make the car ride/feel/whatever like a bmw. it doesn't.
right now with the initial settings at 4 or 4 1/2 that sam starts most people at from hard up front and full soft on the back with strano springs, it rides for the most part like cut springs and stock shocks at low speeds less than 60. higher speeds at 80+ are noticeably better than my cut springs setup. control got better but none of this night and day that i've read on here. i'm on vredestein 245/35/19 fronts and 275/30/19 rears. on these tires, there is little mentionable difference from 2.5" lowered front and 3-4" lowered rear on stock shocks and springs that were cut.
tires play a major role in ride quality and control, but with these tires, ride comfort is not much better, control is noticeable though. also with strano springs, it took the ride height up which in itself helped what was noticed. i am probably the first to not like the konis and post on here. maybe everyone else has such a shitty ride that they think the konis helped a lot. but coming from a huge drop using cut springs, i doubt my setup was much better than everyone elses.
My car with konis alone was a total night and day difference in ride and control, and it rode "good" for a stock fbody.
What is your tire pressure set at? Did you directly talk to Sam about how to set up your car? Take into consideration you have more unsprung weight with those larger wheels than most other people running Konis, your settings may be different than everyone else. You mounted the front springs on the upper perch right?
Jakes Dad
Jakes Dad
Hopefully you can get the ride better to what you are wanting. Sam I installed some of your springs today and I must say BADASS! I love them.
Obviously the wheels arn't helping any, but from what I've read everyone with SFC's have noticed a harsher ride, and worse impact comfort.
what can be said about sfc's is moot, i'm comparing the same setup and everything else on the same car vs a strano springs/koni setup, which did not give me a mentionably better ride quality. i will be making adjustments to see if things get better, but right now with what stated, this car does not feel comfortable as a bmw and i would be shocked if this package is to rival or beat a z06 on the track. this is my experience thus far with the setup as stated and i will be making adjustments when i get some time and see what the problem is and if it could get resolved through adjustments. i'm still in the review process on everything and will make a topic when i have more input, but bottom line is as stated, if you have my setup, it rides like crap for the most part, handling is better, but far from great.
i will be get a hold of sam on suggestions and hopefully be able to make a better report and will post a topic.
wheels aren't so much the problem as much as tire size, but the fact remains with the initial settings and same wheels/tires with the crappy springs and tires, there is very little mentionable difference in ride comfort vs the konis and the strano springs. strano springs are good since they raised my car up from the cut springs i had which allows for better shock movement. i doubt weight at the wheels means much. front tires/wheels weigh 57lbs and rear tires/wheels weigh about 60lbs.
