Bleeding an ABS unit.
Which device would I need other than the Tech2 programmer to bleed the ABS-unit?
(its an export Z28 1998,with no bleeders on the ABS unit)
I have read the Tech2 is needed to rehome the units inside the abs...
Not sure, but even there are few real Chevy dealerships that could do it ,since the coming of the korean cars being renamed as 'Chevrolet'
Also like to do things as much as I can myself,just are not confident if someone strange touches my car...(had some bad experiences over the years)
Not that I need it right now but just thinking ahead in case anything happens if I replace the brake lines and/or calipers.
Good to know there is a way around the techtool,
as said no so easy to find.
so drive, engage abs, then rebleed ,etc ,it sound like a good practical solution,so will do that if required ,thanks for that.
The unit or system looks like its Bosch made , obd2 talks to the ABS over the serial port ,should be able to give the homing command or procedure as a string or such.
But how?
Everybody for the great forum here; I read it with much pleasure and learn a lot!
But how?
