Drop that ASS!!!!!!!!!!!!!!!!!!!!
Drop that ***!!!!!!!!!!!!!!!!!!!!
This is probally stupid but, I want to lower the rear of my car only. And only about a half to three quarters of an inch no more. I just want the car to sit level. Have you guys ever done this?
Moderator
That's about what the heater hose mod will give you.
Slightly less drop than the -1" Hotchkiss I used to
have out back. More than 1/2" though.
Maybe you get a pair of junkyard isolators and shave
on them, if you want only half an inch.
Just use 1/2 " I.D.fuel/oil line hose 37" length total for 2 springs.
Don't split the hose length wise, just cut it in half at 18.5".
I used windex sprayed on the spring and in the hose right before sliding the hose over the spring .slide it on until the end of the spring is recessed at least 1/2" from the end of the hose.
If your worried about the 1/2"hose being too hard to slip over the spring then just get some 5/8" hose, but no bigger than that.
