Who can help me fix my car! Want start
Ive been messing with this thing forever and cant figure it out. My car will not start and idle i can make it run if i pump the gas pedel but sounds like its not running right when i do its real choppy and my car has a stock cam. i changed the relay under the hood and the whole assembley in the tank.
this all happened right after a second gear wot pull and the car just died on decel for a while i could crank the car over but now the battery is getting dead
Now what is there anything else i can do?
I don't think it's the fuel pump tho. If it was the fuel pump it wouldn't just quit without notice. I'd probably do some weird off and on ****.
I think unplugging the MAF is a good test tho. If it doesn't work and you have fuel pressure (start the car for a minute, turn it off and press the shrader valve on the fuel rail), then it's some sort of sensor.
Bottom of the line tho, there's something you're not telling us because a car hardly EVER just quits running without any kind of notice...
Charlie: What are you talking about stretching the wiring harness? What wire would be stretched? That would also link back to his engine mounts if a wire was stretched...
OK i changed the pump, fuel pump relay checked lots of sensors, unplugged the maf and still nothing... i have good fuel pressure i think and it was pretty high like 60 psi with the key on. and when started it was still high. i can start the car if i pump the pedal.
Joe...its hard for me to explain by typing...but being the first run year for these cars some 98s have had the problem of stretching the harness when the engine is torqued...along with computer problems...not very common but its happened...and sometimes its not problems but flaws that could use improvements
