Idle Issue
Idle Issue
I recently had a fresh motor put in and car is Ideling kind of high takes it a while to come down when I come to a stop. I just wanted to see if someone know someone that would idle the car down. Or know someone that would. Please help.
yuppers what Bad chad said .... Give us some more details on your set up and if anything changed .. If you got more mods done to your car the Air Flow tables couldve been jepordized on the tune. Could be a vacuum leak , or maybe IAC , or MAF issues ..
More details Please sir
went from 5.7 to 6.0 the check eng. light was on so I stopped by the local autozone they said the TPS sensor and the MAF were out going to pick them up when I get off of work I hope that Fixes the issue.
ok guys looking for some help me and my turner are getting into it. And I cant find any answers anywhere! I jut did a motor build and he tuned my car before everything went fine I ended up having to replace the pcm and alternator. So he retuned it and it is idleing around 1800 to 2000 and then it calms down then start idleing high again. Any suggestions on what it could be? i also am having a misfire?
