Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
TSP 408, built auto, 12 bolt rear, 99 z28 and extras 14000 obo TRADES!
Old 02-14-2011, 03:10 AM
whitedevil's Avatar
Default TSP 408, built auto, 12 bolt rear, 99 z28 and extras 14000 obo TRADES!
Year: 1999
Make: Chevrolet
Model: Camaro
Price: $14000
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): AZ
Color: Silver
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
After many years I am selling my 99 z28 ttop originally 6 speed. body has just over 100k on it. Engine has approx 2k in break in miles. AC blows ice cold, heater blows hot NO TTOP LEAKS, no smoker. Paint has MINOR clear coat peel in a few spots, but other wise looks great. really is a pretty car. Ive owned this car for about 6 years, and all mods were performed by me, and Brad Fayhee at fayhee motorsports, who specializes in lsx and ltx performance.
[img][/img]
Car is a BLAST to drive, and this tsp 408 literally DESTROYS my old 346 turbo setup, N/A, and this motor is built for boost. I intended on turboing this motor, but now its just not in the cards for me anymore. Motor can make 1000 horsepowe easy with the right set up Car will need new rear tires, as they dont seem to last long behind this motor. Now, for the nitty gritty on the car.
Engine:
TSP 408, build sheet below.
SHORT-BLOCK
GM 6.0L Cast-Iron Engine Block 699.00
Callies CompStar 4.000 Stroke LS1 Crankshaft 959.99
Callies Comp Star LS1/LS2 Connecting Rods, Set of 8 599.99
Diamond Racing Forged Piston Set: 4.010 Bore, 4.000 Stroke,
6.125 Rod Length, 1.115 CD, -28cc Dish, Includes HD H-13 Wrist
Pins 809.99
Texas Speed & Performance Exclusive Total Seal Ring Set: 4.010"
+ .005", 1.5mm AP Stainless Top, 1.5mm Napier 2nd, 3mm Oil 249.99
Camshaft Bearing Set for LS2 and 2nd Gen LS1 Engine Block 33.99
Clevite LS1 H Rod Bearing, Per Bearing 71.92
Clevite H Main Bearing Set, For LS1 Stroker Applications 106.99
ARP Main Stud Kit for LS1/LS6-Based Engines 189.99
Full Block Work and Preparation: Vat Block, Line Bore, Install
New Cam Bearings, Bore/Hone with Torque Plate, Balance
Rotating Assy., Line Hone 875.00
GM LS1 Oil Restrictor 5.99
GM LS1 Oil Galley Core Plug 3.94
GM LS1 Large Coolant Plug 7.99
GM Engine Block Small Coolant Plug, LSx-Based Engines 6.99
Assemble Short-block 400.00
MISC. PARTS
Precision Race Components Stage 2.5 LS6 Cylinder Heads: New
GM LS6 Castings Outright,Stainless 2.04/1.60 GM Valves,
Assembled with PRC Double Valve Springs 1,385.00
Comp Cams Custom Order Camshaft: 354.99
Texas Speed & Performance 7.40 Chromemoly Pushrods 90.00
Cometic LS1 MLS Cylinder Head Gasket, 3.91 Bore, .040
Thickness, Per Cylinder Head 120.00
ARP 12 Pt. Head Stud Kit for LS2 1 241.26 241.26
Comp Cams OE-Replacement Hydraulic Roller Lifters, SBC & LS1 180.00
GM LS1/LS2 Rear Main Seal Housing Gasket 17.70
GM LS1/LS2 Timing Cover Gasket 18.36
GM LS1 Valley Cover Gasket 17.87
GM Oil Pump O-Ring for LS1/LS6 3.73
GM LS1/LS6 Balancer Pulley Bolt 3.82
LS1 Oil Pan Gasket 28.85
GM LSX Rear Main Seal 16.09
GM LS1 Front Crankshaft Seal 16.19
GM LS1 Water Pump Gasket, 7.42
TOTAL 7281.78
TAX 8.25
TOTAL 8164.42 +++SHIPPING
Exhaust consists of texas speed 1 7/8 inch long tubes, and texas speed 3 inch ory, and flowmaster cat back.
Transmission:
XTREME TRANSMISSIONS PRO-STREET 4L60E /4L65E 600 + HP- LEVEL 3
New electronics, New Accumulator Pistons, Teflon Pump Bushing, New Valve Body Spacer Plate , Modified Pump Assembly, Oversized Boost Valve, Transgo Hi-Rev Release Springs, High Quality Overhaul Kit, Frictions and Bushings, Transgo Shift kit, Borg Warner dual cage 29 element Input Sprag , 4th gear billet servo kit, Billet 2nd gear Servo kit, Wide rear sun gear bushing, Heavy duty sun gear shell “The Beast”, Upgraded Bearing Type Reaction Carrier Shaft, Wide High Energy 2-4 Band, 4L65E 5 Pinion OEM Front and Rear Planetary Set, High Energy 7 friction clutch pack with full thickness Kolene Steels, Input drum Steel sleeve prevents input drum breakage at spline area, High RPM Transgo pump slide spring and pump rings.
Yank 3500 stall
Suspension:
BMR tubular LCAs
Hotchkis panhard bar
Heavy duty front swaybar
all poly bushings including motor mounts
Exterior:
American Racing TTM wheels, powdercoated black with machined lip. 17x11 rear and 17x9 front
Black slp ss hood
pewter ss spoiler
tinted tailing lenses
whistler mod
tinted corner lights
tinted windows
Interior:
Car recently underwent a full ebony black leather interior swap and its sweet. absolutely no staines, non smoker, perfect in allmost every way, only flaw is a small crack on the dash. full blue LED interior swap, including all gauges and buttons.
Autometer pro comp boost gauge
Autometer pro comp fuel psi gauge
Aem Wideband
Autometer 3 pillar gauge pod
radar detector
pioneer head unit, sub in stealth box, and 2 farad cap
I am interested in trading for a Trail Blazer SS, possibly a GTO. Ill entertain ALL trades though, worst I can say is no. I love this car, and its very fun to drive, easily capable of mid 11 second passes as it is now, throw boost at it and it would be one hell of a ride! I know im leaving other parts out, there is just so much in it, allmost no miles on everything in it. I just need something a little less radical, something more suited for me as I may start moving around a lot. $14,000 as it sits, and id be willing to make a deal on car and extra non installed parts. feel free to text or call with any questions 702 five five six 4718
Old 02-14-2011, 09:50 AM
Croman's Avatar
What happened to the turbo you where selling with the car?
Old 02-14-2011, 01:42 PM
whitedevil's Avatar
I am returning it since i havent had it for anymore than 2 weeks
Old 02-16-2011, 03:42 AM
whitedevil's Avatar
bump. thanks for looking ppl.
Old 02-16-2011, 09:33 PM
whitedevil's Avatar
to the top. getting ready to put new shocks/struts on her
Old 02-17-2011, 11:28 PM
whitedevil's Avatar
pm's replied. bump on up
Old 02-20-2011, 08:06 PM
TheLS1Lover's Avatar
Could you email me some interior shots? striker7510@gmail.com
Old 02-20-2011, 08:19 PM
01 WS6 6.0's Avatar
Very nice ride...is that your chevelle?
Old 02-20-2011, 09:23 PM
Silver Rocket's Avatar
I got a silver 05 gto with 55k on it, I would love a camaro again
Old 02-21-2011, 02:55 AM
whitedevil's Avatar
send pics and info on the goat.
kflink@gmail.com
thanks for the compliments, that chevelle is my friends car.
ill send interior pics.
Old 02-21-2011, 11:09 AM
01 WS6 6.0's Avatar
kflink@gmail.com
Is it for sale? Looks real nice whats it got in it?
Old 02-21-2011, 04:05 PM
whitedevil's Avatar
pics sent.
The chevelle has a tall deck lsx 440 in it, 15 psi boost as of late, its a killer ride. na to na, by car walked all over his though, so i could only imagine how fun mine will be at those boost levels he sees now. **** is awesome.
Car is still up for sale or trade, lots of offers on trucks and stuff that just dont suit me right now. thanks for looking everyone
Old 02-21-2011, 10:25 PM
Croman's Avatar
do you have any dyno numbers?
Old 02-22-2011, 01:27 AM
whitedevil's Avatar
unfortunately. no. I was waiting to turbo this thing again to do so. im not even sure there is one where i live anymore. vegas is only a short trip away though.
I cant stress enough how much faster the car is now on the street over the old setup, and i went 11.5x that way. I made one pass at vegas with a passenger, a whole set of wheels in the back, and a tool box in vegas at the mayhem event with this new motor, and went deep into the twelves just goofing off. I really wish i would have ran this thing all out with only me in the car with my prostars on it. but i may never know.
Old 02-22-2011, 11:41 PM
Croman's Avatar
Thanks for answering my questions up to this point. when you look at your car from the left side, it looks like the front fender is dented in by the door. Also why is the front grill missing and lights out of the bumper?
thanks
Old 02-23-2011, 12:35 AM
whitedevil's Avatar
It is not dented in, now that you mention that i had to scroll up and look, im assuming additional shadowing there makes it look that way, i will gladly take a close up pic tomorrow. the lights are infact in there, you can see one in the first pic. the grill is missing because the car had an intercooler in it with my old setup, and i intended to have another one in, as i was going to be boosting this thing again with the new motor. ill take pics of the framework done to mount the intercooler as well.
Old 03-10-2011, 10:13 AM
r572cobra's Avatar
what part of az,are you from and what is the rearend.
Old 03-10-2011, 10:16 AM
r572cobra's Avatar
sorry i meant what gear.
Old 03-10-2011, 08:30 PM
hunterdawgs's Avatar
nice car...sounds like a great price also
Old 03-11-2011, 02:32 PM
Golf&GM's Avatar
Beautiful! What's with the stock lid though? Sorry if I missed it in your first post.
Quick Reply: TSP 408, built auto, 12 bolt rear, 99 z28 and extras 14000 obo TRADES!
