FS: 2000 6.0 Twin Turbo/4L80e Trans Am
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $19000
Mileage: 79000
Private or Dealer Listing: Private Listing
Location (State): NY
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
This car previously belonged to jt76 here on the forum. I purchased the car in April, but I have decided to start my search for a C6 (and I miss the third pedal!). The car has the potential to be an absolute monster. Through the T56, the car made 803/790 on a dynojet on about 12psi of boost, 93 pump gas and 13-14* of timing. It put down 842/844 on 17psi on a Mustang dyno. Please read the ad in its entirety if you are interested in the car.
The Bad
-The car was converted from a T56 to a built 4l80e last summer and has not been fully dyno tuned since. The car was on a dyno in mid May, but the session was ended early due to a fitting on the radiator letting go. The tuner improved a low speed stall/stumble issue and tuned the car to about half throttle. A final tune with WOT will be needed.
-The exhaust where the cutout is hangs very low and will most likely need to be adjusted for street driving; the cutout will just barely scrape every so often as it sits
-The low oil light is currently on, I need to plug the sensor back in but keep forgetting
-The trans. pan gasket is seeping and will leave a few drips after sitting a while
-The button to reset the wideband needs to be rewired, the solder fell apart while cleaning up some wiring under the dash
-I am having an issue where on maybe 1 out of 20 starts the starter is continuing to try to engage with the key off; I believe this is an issue with the power wire going to the starter and will be looking into it this weekend (6/25)
I will disclose any other things that come to my attention. Some of these issues are very minor and quick fixes, but I want to be as detailed as possible if someone were to come see the car as it currently sits. I would not recommend this car to a novice mechanic. Someone familiar with highly modified/turbo cars and the ability to troubleshoot issues that will come up would be the ideal buyer.
Engine
-Forged motor built by Jason @ J&J Speed shop
-6.0 Iron GenIII block
-Mahle forged and coated pistons
-Callies Compstar rods
-Stock polished crank
-Calico coated bearings
-ARP 2000 rod bolts
-ARP head studs
-ARP cam bolts
-Ls9 headgaskets
-Rollmaster timing chain
-Melling oil pump
-Powerbond 10% udp
-LJMS custom turbo camshaft
-BTR dual springs/ti retainers
-317 cyl heads
-Ls6 intake with ported TB
-Kurt Urban Performance steam vent system
-Griffin radiator tucked under the front support
Turbo Kit
-Custom stainless twin kit by Joe @ Straightline performance
-V-bands used throughout, everything is vibrant or treadstone
-Precision 6262 billet/ported shroud V-banded turbos
V banded truck manifolds
-Tial MVS-R wastegates
-Tial-Q bov
-Treadstone twin intercooler with aluminum charge piping and vibrant couplers
-Turbosmart "E-Boost2" electronic boost controller
Drivetrain
-GM 4l80e transmission from 2005; rebuilt with heavy duty clutches, billet shaft, transgo HD shift kit.
-TCI LS1 SFI flex plate with ARP hardware
-Circle D billet triple disc converter
-B&M trans cooler with braided steel AN lines.
-Driveshaft was custom made by fleet pride with a billet yoke.
-Rear end is a Moser 9" with a Detroit tru-trac heavy duty differential with Moser 31 spline axles. 3.25 gears; this setup is pretty noisy going around turns (clunking)
Fuel system
-Lonnies double pumper in tank setup
-8 feed and -6 return lines with a/n fittings
-Aeromotive fuel rails
-Fuel lab boost ref FPR w/gauge
-Siemens Deka 80lb injectors
Exhaust
-Both 3" downpipes merged to 4" cutout with dump
-4" QTP electric cutout; toggle switch mounted under radio
-4" necked down to 3" after cutout
-Borla Catback
Suspension
-QA1 adjustable coilovers on the front
-QA1 adj shocks on rear
-QA1 springs front and rear
-BMR chromoly K member
-BMR LCA's
-BMR adjustable torque arm
-BMR trans cross member
Interior
-Autometer ES series Boost gauge
-Autometer ES series electronic fuel pressure gauge
-Autometer ES series Oil temp
-Autometer ES series trans temp
-Innovate wideband with DB gauge
-Eboost 2 boost controller
-Corbeau TRS leather seats
-Trunk spare tire well mounted Summit battery relocation
Exterior
-"Blackbird" hood stripes
-"CETA" rear valance mod
-There is a scratch along the lower passenger door and thinning clear coat on the passenger rear fender (looks to have been repainted); no large dents or other major paint issues
Misc
-The car does not have HVAC installed
-The car has a linelock that is not currently hooked up
-The backseat has been removed and I do not have it
-Airbags are not currently hooked up due to the horsepower of the car
$19,000 with the Darkstars
I have no issues if the buyer were to bring their own wheels for the car. We could discuss that price but it would obviously be less than $19k.
The car is located in Syracuse, NY and has a clean title with no liens. Please see below for jt76's build thread and a past FS thread with more pics and videos. Feel free to post here or message me with any questions or requests. My phone number is 315-4three0-8zero72.
https://ls1tech.com/forums/forced-in...treet-car.html
https://ls1tech.com/forums/vehicle-c...-pump-gas.html
