Western Members CA, AZ, NV, UT, CO, NM, HI
my computer won't start up... stop screen?
Old 06-17-2009, 01:30 PM
Banned Village Idiot
LS1BLKSS's Avatar
Default my computer won't start up... stop screen?
my damn computer at my desk is sick... this blue screen pops up says:
A problem has been detected and windows has been shut down to prevent damage to your computer
If this is the first time you've seen this stop error screen, restart your computer if this screen appears again follow these steps:
Disable or uninstall any unti-virus, Disk degragmentation or backup utilitics check your hard drive configuration, and check for any updated drivers. Run CHKDSK /F to check for hard drive corruption and then restart computer
Technical info: STOP 0X00000024 (0X00190203,0X8235D2D0,0XC0000120,0X00000000)
i tried fixing it searched to fix it and i do everything it says but it still comes up
Old 06-17-2009, 01:42 PM
benoh's Avatar
Not sure what kind of info / files you have on your computer but here's my recommendation as a IT.
Pull your hard drive from your computer and stick it in another computer as a slave drive. Backup all the files you need on either a external drive or flash drive. Make sure you scan the files that you are backing up with a antivirus program.
After the backup, just reformat your computer with a fresh copy of Windows. If you don't have a install CD, I'm sure one of us has one.
Feel free to PM if you have any questions. Good luck with your computer dude.
Old 06-17-2009, 02:23 PM
DobsZ28's Avatar
^^^hmmm...well, I would definitely try some other things first before you go reformatting anything. if you've already restarted the computer and you keep getting the screen, reboot the computer, and press F8 a couple times, until you hear a BIOS beep. By doing that, it should prompt you to a black screen that will ask you how you want to start your computer; i.e. Safe Mode, Safe Mode with Networking, Safe Mode with Command Prompt. Starting the computer in safe mode will basically disable all of the drivers that could be causing your blue screen. Try a system restore to a couple days ago, and see if that works.
If you can get into Safe Mode, your hard drive is fine, and you won't need to reformat anything. If you can't get into safe mode, either your hard drive is defective, or your operating system is corrupt.
What I'd do personally is start the computer in Safe Mode with command prompt, and if you have your Windows disc, or even if you don't, type in the following command: "sfc /scannow" make sure to leave a space between the "c" and the forward slash. This will go through your Windows and essentially fix any problems that there are.
If you continue you have more problems, let me know, I see this stuff at Geek Squad all the time.
Old 06-17-2009, 02:53 PM
LS1BLKSS's Avatar
i really don't have any files i need to save, there are some but not that imporant so i can restart the whole computer, i tried to go on a safe mode but it won't let me, the blue screen just pops back up again
Old 06-17-2009, 03:22 PM
ROCNDAV's Avatar
http://www.geekswhoknow.com/articles...error-code.htm
Old 06-17-2009, 03:29 PM
LS1BLKSS's Avatar
^^^ nice i'll try that i need a floppy disk now
Old 06-17-2009, 03:39 PM
LS1BLKSS's Avatar
i got a floppy now but that damn computer doesn't have a drive for a floppy LOL... maybe i can load and save it into a cd??
Old 06-17-2009, 05:44 PM
RooRnZ28's Avatar
first run CHKDSK /F and see if that fixes anything
Old 06-17-2009, 07:25 PM
DobsZ28's Avatar
blue screen going into safe mode means most likely bad hard drive...if you dont have any valuable data, just try a full system restore
Old 06-17-2009, 07:26 PM
LS1BLKSS's Avatar
^^^ i think thats what im gonna do with it, nothing valuable on it just **** j.k
how can you run CHKDSK /F?? what do you do?
Old 06-17-2009, 07:27 PM
LS1BLKSS's Avatar
right now im using the computer next to my desk until i fix the one that is blue screened!
Old 06-17-2009, 07:39 PM
PedaltoMetal's Avatar
What is the code right after it says
"A problem has been detected and windows has been shut down to prevent damage to your computer"
Old 06-17-2009, 08:27 PM
hlaalu's Avatar
good ol' blue screen of death. bring your computer down the basics.... take out all but one RAM stick, take out any video cards or other accessories and see if it starts.
Old 06-17-2009, 08:30 PM
LS1Adam84's Avatar
Nahh it's hard drive safe mode won't come up, hd is toast most likely, if it was memory it would beep several times consistantly on start up. Sorry man time to reformat.
Old 06-17-2009, 08:34 PM
hlaalu's Avatar
i guess if he has really nothing to loose on the hdd he can reformat but i would save that for last. but if the harddrive is bad a reformat isn't going to help. i would troubleshoot one step at a time first
Old 06-17-2009, 08:42 PM
CaliforniaBoy5's Avatar
If you can wait till when I come back from rafting (sunday night) I can take care of it Joser. Just LMK.
Old 06-17-2009, 09:33 PM
ConElite's Avatar
Yeah you have bad software. Just reformat it. Its easy just a little time consuming downloading all the gawd damn updates. I do this crap at least 2-3 times a week!!
Nobody ever downloads the updates!!!
Screw it, I got an iMAC 19" see how i like it. only had it a week. like it do far
Old 06-17-2009, 10:45 PM
ZexGX's Avatar
If reformatting doesn't work or you have weird problems reinstalling Windows, it's a bad hard drive... If I were you I'd take up Cesar on his offer.
Old 06-17-2009, 11:46 PM
LS1BLKSS's Avatar
it doesn't say any other code
LS1BLKSS's Avatar
yes can do you that for me???!!! i don't want my boss to get all pissy right now
Quick Reply: my computer won't start up... stop screen?
