Western Members CA, AZ, NV, UT, CO, NM, HI
So I figured out why my car ran a 13.5 @ 104...
Old 06-09-2011, 12:18 PM
ZexGX's Avatar
Default So I figured out why my car ran a 13.5 @ 104...
I got George Lara to take a look at the tune with HPTuners and we found that both knock sensors are bad (or the harness... the harness is new and the sensors have 95k miles on them, and it has been throwing knock sensor DTCs), and the PCM is pulling timing at WOT. Apparently it was getting down to 18* at WOT due to the 22* peak timing that George had set up a while ago due to the knock sensors reporting [now false] knock. We did a couple of test pulls with a temporary fixed constant 26* of timing and it pulled great with no audible knock. Did the same pulls again with the default settings of a maximum of 22* and it pulled timing and felt like a dog. Also made a few more changes with the fuel trims. Car feels better now than at Invasion, but I still need to get a dynotune from Ryne or George when I can afford it. Have to replace the knock sensors before getting a dynotune or taking it to the track.
Old 06-09-2011, 12:27 PM
LS1Tech Editor
loloone's Avatar
Lee, your unwavering dedication is unbelievable. See that bish through to the end, it'll all be worth it the first time you get the time slip you're after! Ever address that trans problem?
Bravo sir, bravo.
Old 06-09-2011, 12:49 PM
ZexGX's Avatar
Bravo sir, bravo.
Thanks. I actually drove to Menifee to pick up a built 4L60E for $600 on Saturday and we replaced the trans and converter at RMS on Sunday. Has a stock converter right now. Both work great.
Old 06-09-2011, 01:08 PM
98BLOWNZ28's Avatar
Lee bought a simi built trans and replaced the stall with a stock one. He said that alone helped cause we kinda think his other converter went out.
Glad to seeit running though.
Old 06-09-2011, 01:09 PM
ZexGX's Avatar
Yup, it was the converter or the pump.
Old 06-09-2011, 02:39 PM
Sommer86's Avatar
I have still yet to hear the car....and i park next to it everyday, lol.
Old 06-09-2011, 03:15 PM
KILLER-LS1's Avatar
lee, i have a few low mile, no corrosion knock sensors if youre interested. I just bought two new ones from the dealer and they were almost $75 each!
Old 06-09-2011, 03:29 PM
ZexGX's Avatar
I was thinking of getting Delphi sensors from RockAuto brand new for $40 each... Don't have the $$$ right now though.
Old 06-10-2011, 03:16 PM
ROCNDAV's Avatar
Lee, how much do you want for your old core?
Old 06-10-2011, 03:49 PM
ZexGX's Avatar
I have it listed on Craigslist for $100 and the converter goes with it. If you want it, you better get it soon. It'll be in the desert as of late tomorrow morning. It currently has the truck output housing (F-body length) and slightly deeper truck pan. Guy had the output shaft housing and truck pan on a Strano lowered F-body with a tunnel mount torque arm and the pan has no scratches on it, so he never scraped it.
Old 06-10-2011, 05:17 PM
ROCNDAV's Avatar
I'll take it, if you can hold off until pay day (15th)
Old 06-10-2011, 06:12 PM
ZexGX's Avatar
PM sent. BTW, the transmission is in Burbank.
Old 06-10-2011, 09:30 PM
tripblackls1's Avatar
hey lee i have extra knock sensors that you can have!
Old 06-10-2011, 10:04 PM
LS1Adam84's Avatar
Uhh so it might have been good to get the converter checked right Lee?.... Hmm?
Old 06-10-2011, 10:59 PM
BigDaddyBry's Avatar
George is a good guy.
Old 06-10-2011, 11:29 PM
ZexGX's Avatar
Why the hell would I spend money on testing a sub-$100 converter when the 3-4car clutch packs were taking a ****?
Old 06-11-2011, 06:21 PM
LS1Adam84's Avatar
Why would you waste money on a $100 converter to begin with?
Old 06-11-2011, 06:32 PM
C5natie's Avatar
Lol at you guys. When you go cheap you pay twice.
Old 06-11-2011, 07:38 PM
lowerthanyou00's Avatar
Let's see 12s lee
Old 06-11-2011, 09:19 PM
Raptor_WS6's Avatar
Originally Posted by lowerthanyou00
Let's see 12s lee
we did last year with a hurt motor and trans lol
and a cracked flexplate
Quick Reply: So I figured out why my car ran a 13.5 @ 104...
