Western Members CA, AZ, NV, UT, CO, NM, HI
Best underdrive pulley?
Old 01-14-2006, 12:16 PM
Slammed99s10's Avatar
Default Best underdrive pulley?
Did some searching last night but didn't come up with squat, maybe I was searching for the wrong word(s) who knows
Anyhow what's everyones opinion on the best underdrive pulley out there (ASP, SLP, Powerbond, etc)? I'm wanting to get one soon and don't like cheap (not $$ wise but quality wise) **** on my vehicles because you'll pay twice as much in the end. Thanks.
Old 01-14-2006, 12:45 PM
bmfcamaro's Avatar
i have asp w/ no problems
Old 01-14-2006, 12:49 PM
SSU's Drunk Typing Whore
Lithium's Avatar
ASP here as well.
Seems to be the most popular choice on here.
Old 01-14-2006, 12:52 PM
Originally Posted by Lithium
ASP here as well.
Do either of you use the alternator pulley as well or just the U/D?
Old 01-14-2006, 01:32 PM
blazinws6kush's Avatar
Asp is lighter, SLP weighs the same as the stock pulley. I think the SLP looks better though. My bro has asp in his 00 SS. I heard the asp has to be modified to install a cam.
Old 01-14-2006, 01:40 PM
Lithium's Avatar
True. But only with the double roller timming chain. Still then the newer version of the asp pulley(SFI appoved)will fit. Its the older ones that need to be modified.
Old 01-14-2006, 02:02 PM
Lithium's Avatar
I got the alternator pulley as well. No problems at all and only like 22 bucks I believe.
Old 01-14-2006, 03:07 PM
sercastiK's Avatar
March is the best IMO..
J
Old 01-14-2006, 03:49 PM
So if I understand you correctly the newer version of the asp won't need to modified to fit a double roller chain? I do plan on upgrading the oil pump and chain when I get a cam done. Did asp change the part #'s between the non sfi and sfi approved or is there a visual difference between the two?
Old 01-14-2006, 04:26 PM
Lithium's Avatar
From what I have heard the newer version of the pulley is the one with the SFI sticker on it. Mine fit fine cause I bought it at the begging of last year.
Not sure on the part numbers, I am guessing its the same. There is a visual difference here is a pic ----->
http://www.ls1howto.com/howto/fbody/...p_machined.jpg
Do you have the pulley already? or are you planning on buying one later on.
Old 01-14-2006, 04:52 PM
GTObsessor's Avatar
same here... you don't need the alternater one unless you have a HEUGE stereo or something like that that sucks a lot of juice.
Old 01-14-2006, 05:02 PM
Naw just looking into which one to buy and plan ahead so I won't have to replace parts later on.
Big stereo & sucking juice those days are over with, plus more stereo = more weight = slower LOL.
Old 01-14-2006, 05:09 PM
Lithium's Avatar
Oh, then when you buy the ASP you will be fine.
Old 01-14-2006, 05:42 PM
GTObsessor's Avatar
Haha... same here... had some heuge subs in my Trail Blazer... but I wanted something fun... no need for that slow gas sucker in So Cal... oh yah... and True Duals make for a nice sound system
Old 01-14-2006, 08:55 PM
bmfcamaro's Avatar
i did not. i didnt want to have any charging issues. buy a gatorback belt to go with whatever pulley. dont learn the hard way.
Old 01-14-2006, 09:01 PM
Lithium's Avatar
You need the overdrive for a system if you are having charging problems.
Old 01-14-2006, 10:56 PM
GTObsessor's Avatar
bah joo know what i mean lol... i've got over a 13 volt charge at startup - 25% UD pulley only
Quick Reply: Best underdrive pulley?
