For those spraying in CA..
Hey fellas.
Just have a quick question. Currently plan on putting heads on my cammed car and also spraying a 100 shot (dry) on top of that. With the heads my static compression ratio will be around 11:1. With that high of a compression will I be able to spray on pump gas (91 octane here in CA)?
I do plan on upgrading my fuel system to support the added power so I should be OK in that department.
Thanks for the help.
Brian
Brian
I like the insurance of putting in a few gallons of race gas before running on the squeeze. If you put a simple retard box wired into your nitrous system that would make it safe for sure. I'd pull 3-4 degrees out when spraying. The retard box makes it so you aren't giving up power the rest of the time, like you would be if you just dialed back your advance by 4 degrees all the time.
Jim
Jim
I sprayed a 125 shot on an 11.2-1 motor with 8-1 dynamic compression with no timing pulled out. I have 28.5 max timing for wot. Every car will be a little different so you really need to just do it and tune around what you will be spraying. You can program in some timing retard on a dry system based off the iat senors. It is under a timing vs temp table.
those spraying are a bunch of pussies that cant race a real race, they have to go out and push that ***** button like a bunch of little bitches, squeezin is a bitch move
My case I will only squese if its for money
I THINK WITH A LITLLE MORE UNDERSTANDING YOU'LL SEE IT'S A GOOD BANG FOR THE BUCK MOD........
NAAAAAAAWZZZZ...
yeah NAWZ is awesome.. like i walked into a "Speed Shop" and had to get NAWZ because my car topped out at 160mph.. so i had to get one of the big bottles.. no wait.. i got 2 of the big ones!!.. then when i was racing.. my laptop was flashing a danger sign.. and said critial manifold pressure.. but i just slamed it down and yelled " SHUT UP" and kept on racing... im the man... NAWZ is awesome..
You mean when I hit the button, the streetlights won't blur and I immediately go from 140 to 160mph????
No way, man, I saw it right on the screen in front of me! They can't make that **** up...
Jim
Jim
yeah its totally true... and once you do hit that button... the street turns into a 20 mile straight, with no cars on it.. and an endless amount of ricers parked on the sides..
and then all the Ballz Deep guys will come out saying how much they rule because they just waxed a civic..
NAAAAAAAWWWWZZZZ!!!!!!!
With NAWZ and my MaD SkiLLz, I can't lose, Yo!
I think that whole movie was conceived by someone that installed the fogger nozzle in their steering wheel, pointed right at their mouth. That's the only way it makes any sense...
J
J
Originally Posted by GR33N GoblinM6
NAAAAAAAWZZZZ...
LMAOLMAOLMAOLMAOLMAOLMAOLMAOLMAOLMAOLMAO
YOU GUYS ARE NUTS!!!
J
J
