View Poll Results: would you
yes
13
68.42%
no
6
31.58%
Voters: 19. You may not vote on this poll
315/17 nitto????
Old 04-02-2009, 02:48 PM
robsquikz28's Avatar
Default 315/17 nitto????
can they and would u put them on a 9.5 wide wheel....remember these tires run a lot smaller than a m.t would and i have seen peeps do it but would ls1tech peeps recommend this for the street....
Old 04-02-2009, 02:56 PM
STEEPSS's Avatar
i'll be the first to say it, READ THE STICKY.
but, that aside, i would just PM someone on here who's done it without issues.
you're gonna get your ***** busted for even asking that. just so you know.
Old 04-02-2009, 03:40 PM
AChotrod's Avatar
I can not tell you yes, since Nitto doesnt. But I can tell you I run them on my stock WS6 wheels. Im on my second set and been to the track multiple times with them and never had a prob. And they look sweet! See my sig for a pic
Old 04-02-2009, 05:58 PM
Discount Tire's Avatar
Tire manufacturers make recommendations for your safety. Stick to their recommendations.
www.nittotire.com - view sizes and specs for their rim width recommendations.
Old 04-02-2009, 06:58 PM
fccs's Avatar
They would say no and normally I would to, but nitto is the only tire I would throw on the stock wheels. a 315 to nitto is a 275 to our normal sizes. They seem to not be able to measure the **** or something right.. So I would say no normally... but go ahead most people do it anyways, I know I wouldnt put a 315 nitto on a 11inch rim, way to wide ( the rim is to wide for the tire).
Old 04-02-2009, 07:14 PM
500hpZ06's Avatar
You would be "pissing in the wind". You will be adding extra tire weight without the benefit of the extra tread/contact patch.
I just put some 305 tires on a 10" wide rim. The 12.3" wide tire ended up at 11.7" after mounting on the 'slightly' out-of-spec recommended rim width (10.5" was minimum, 11" was optimal).
Old 04-02-2009, 07:51 PM
AChotrod's Avatar
you can just run them at a lower psi at the track for better contact
Old 04-02-2009, 09:21 PM
ive seen peeps do it but yet every one cries out loud and says no dont do it....either way that damn nitto runs so damn small its like really running a 275 tire anywa
Old 04-02-2009, 10:02 PM
blkZ28mara's Avatar
So you guys would recommend running 305 nittos on a 9.5 inch wheel?
Old 04-02-2009, 10:24 PM
blkZ28mara's Avatar
Oh wait nevermind, nitto only makes 275s and 315s for a 17 inch rim
Old 04-03-2009, 12:06 AM
tspence45's Avatar
Actually, a 315 Nitto fits a 17x11 perfectly. There's still a tiny bulge, considering the tire is 12.13" wide.
Old 04-03-2009, 11:19 AM
STEEPSS's Avatar
if we're talking nitto STREET tires, I would only put those on a 10.5"+ wheel. DR's, well lets just say i voted yes. The DR's run nearly the EXACT same width as a 275 M/T DR.
Old 04-03-2009, 09:10 PM
up2nuthingud's Avatar
i voted yes because i currently have 275 555 in front and 275 555r in back on 9.5 f&r and the 555r are much narrower. i have seen it done by a few guys on here and they will be my next tires.
Old 04-03-2009, 09:14 PM
fccs's Avatar
This would be normal for a normal 315! NITTO 315 TIRES ARE ALMOST THE SAME SIZE AS A 275. I wish I can show everyone this, I compared my bfg gfroce tires to my friends 315 nitto and they were ALMOST IDENTICAL in width! I don't understand how you guys would say put those nitto 315s on a 11inch wide wheel, thats ridiculous. Go to a tire store and see if they have any, you could measure it yourself and see how there not as wide as they say!
Old 04-04-2009, 03:13 PM
tspence45's Avatar
Ok. I have a 275/40/17 BFG Gforce T/A KD tire sitting out in my shed. It's not as wide as my 315 Nittos. And here, check out some pics I just went out and took of my 315 Nitto DRs on my 17x11 ZR1's. The tire is obviously not too small for the rim.
Old 04-04-2009, 07:35 PM
rel3rd's Avatar
If you parallel park, come a little close to the curb, and your wheels hit long before the tires (like the bottom picture above wheel/tire absolutely would), then they are too narrow for the wheel.
Aside from the wheel lip itself, my 315 Nittos look and fit my 9.5" TT2's nearly identical as the 315 Sumitomos fit my 11" TT2's. I wouldn't even consider doing this with any other brand tire, but the Nittos are obviously exaggerated as to their true size listed on Nitto website. Mine measure 10.5" wide at the tread, roughly 11.5" at the largest part of the bulge. I'm going to say that judging by the above pics, yours show that they are the same 10.5" if measured at the true and actual tread width...the part that touches the ground at normal air pressure (and has dust on it), not the part that's rolled around to the sidewall.
Old 04-04-2009, 07:50 PM
mook99ta's Avatar
What buldge are you talking about? So what your saying is that because you mounted the 315's on a 9.5 you have a buldge in the tread?
I talked to a tire shop about this today and they are pretty reputable and they told me that they would mount 315 nitto's on my 9.5 ZO6 wheels but told me the same thing that there would be a buldge in the middle and cause some wear issues, anyone had that problem?
Old 04-04-2009, 09:21 PM
Lt4TransAm's Avatar
Fit fine on a 9'' wheel
Old 04-05-2009, 08:49 AM
mook99ta's Avatar
Do you have any pictures from the back? And are those DR's or regular nitto?
Old 04-05-2009, 10:53 AM
rel3rd's Avatar
The bulge being referred to, is the sidewall, not the tread. Tire makers call it the section width, I think. On an 11" wheel, the wheel is slightly wider than the tire. On a 9.5" wheel, the tire is slightly wider than the wheel.
Here's shots from the rear, showing what I mean, compared to how they fit an 11" wide wheel:
