Reverse Barrel Wheel??
Old 04-04-2009, 09:29 AM
SmokedOutZ28's Avatar
Default Reverse Barrel Wheel??
What does this mean? And will it effect the fitment & looks of the rim?
Old 04-05-2009, 01:26 AM
Anthony '00 WS6's Avatar
do you mean reverse mount? if so that means the tire is installed on the wheel with the face of the wheel downwards. wont affect fitment whatsoever
Old 04-05-2009, 07:18 AM
Well if you have a reverse barrel wheel it automatically means it will need to be reverse mount. After several hrs of searching the net I've found a Reverse barrel wheel will totally change the look of the wheel (lip wise) but should not affect the fitment.
Old 04-05-2009, 11:20 AM
DRGnFLYZ28's Avatar
I believe you a refering to a wheel with ample negative offset creating a very deep dish look. In the late 80's and early 90's, it was real popular especially on lowered pick up trucks. I saw lots of them from brands like Eagle, Ultra and KMC.
Old 04-05-2009, 11:30 AM
Yes, basically I have the option of turning my TT2's into a completely "Flat lip" rather then the "Stepped Lip" they normally come with but they say the only way to do that is reverse the barrel and I was just wondering if I would run into clearance issues with the brakes.
But going off what I've read about reverse barrels the clearance should be fine. I guess I will find out in 6-8 weeks if it will have a completely flat lip and cause issues with fitment.
Old 04-05-2009, 01:26 PM
94 s dime's Avatar
i think your talking about reverse drop. traditional tires are mounted with the face of the wheel up, reverse drop is with the face down and you mount the tire on the wheel.. shouldnt affect the way the wheel fits
Old 04-05-2009, 01:54 PM
99345hp's Avatar
most custom wheels are reverse drop. They do this so the wheel looks better. They probably dont do this with the TT2's because they are a factory mustang wheel. LOL. The reverse drop really makes the wheels look better and makes them look bigger in diameter also.
Old 04-05-2009, 02:35 PM
94 s dime's Avatar
and usually have less mounting scratches
Old 04-05-2009, 07:22 PM
99345hp's Avatar
you shouldn't have mounting scratches anyways. Take your wheels to a place that has a touchless machine and nothing will ever touch the wheel.
Quick Reply: Reverse Barrel Wheel??
