Can Tire Puncture Be Fixed?
Old 06-13-2009, 12:27 PM
Crimsonnaire's Avatar
Default Can Tire Puncture Be Fixed?
Hi.
Can someone tell me if a tire puncture by a nail can be fixed or is it utterly compromised? The tire in question is a 275/40-17 Falken with about 40% tread, and I don't know how long the nail stem is, but it obviously penetrated deep enough for air to leak out. Also, the puncture spot is about 3 inches from the side edge.
Thanks.
Old 06-13-2009, 12:29 PM
keith_AE2010's Avatar
Most of the time I get my tires plugged for ten bucks. Not completely sure, but try your local tire shop.
Old 06-13-2009, 12:40 PM
Cool! Thanks very much.
Old 06-13-2009, 12:42 PM
89IROC's Avatar
yeah its just when its within like 1/2 or so of the sidewall that they cant fix it...if you have a discount tire near by its a free repair...
Old 06-13-2009, 01:49 PM
Thats good to know. All the places around here charge 10, some more if you didn't buy there.
Old 06-13-2009, 07:29 PM
hitmanws6's Avatar
tires can be fixed if the puncture is inside the tread. there has to be 3/32 of tread left as well
Old 06-14-2009, 07:08 AM
EchoMirage's Avatar
nearly anything can be fixed. you can pick up a plug repair kit at any parts store and do it yourself.
Old 06-14-2009, 08:49 AM
Fabian's Avatar
I've repaired em before with the plug kits they sell anywhere. Wally world, auto zone etc etc
Old 06-14-2009, 08:52 AM
Adam2001WS6's Avatar
Wow... Did anyone mention plugs? J/K
Old 06-14-2009, 10:15 AM
89IROC's Avatar
plugs really arnt the best way to fix a flat, good for a quick fix to get u to a tire store to get them patched...
Old 06-14-2009, 10:53 AM
I would have to agree and disagree at the same time. I would say it depends on the type/severity of the "hole" left in the tire (ie. nail puncture vs. cut/tear). You can simply plug, cold patch or hot patch a puncture/cut or a combination of them. Most plugs these days are what I believe they call "self-vulcanizing" meaning they are inserted in the puncture and heat up as the tires hit the pavement and the plug melts INTO the puncture, sealing it up in the same manner that a hot patch would. Basically, it all comes down to the amount of time you want to spend on it yourself or pay a shop to do. It's much more time consuming to completely dismount a tire to apply a cold or hot patch versus 5 lugs and a plug. As far as paying someone to do it, I think you are looking at $15 for a patch and, I dunno, $5 for a plug...
As an aside, I plugged a nail puncture in my pass. rear Falken last August... I have yet to lose tire pressure from it.
Old 06-14-2009, 05:55 PM
EchoMirage's Avatar
as long as its done right, and using a decent part, a plug can last the life of the tire. i have plugged and know plenty of people who daily drive on plugged tires, getting 50K miles on them. i even know people who have autoxed on plugged tires.
Old 06-14-2009, 10:13 PM
Ugh... must be karma... I got not only a puncture tonight from a nail but also an inch piece of metal in the side wall that ripped a chunk out and was stuck inside there just glaring at me...
Old 07-15-2009, 06:58 PM
jimbo98z's Avatar
Some places don't do plugs anymore because they say it's unsafe and unreliable, which is a load of bull. I worked at a shop that did tires for a while and I had more issues with patches leaking than plugs, not that there were many.
I also put a plug in a tire on my dad's tow rig for his boat one weekend and the plug lasted the life of the tire (another 20,000+ miles).
Bottom line, I haven't seen anything that tells me that there is anything wrong with a plug. In fact, the patches that I preferred to use actually were a patch that had a plug built into the middle so it was kinda like doing both at the same time.
Old 08-03-2009, 01:04 AM
metalmechanic's Avatar
yes and more than once
Old 08-05-2009, 04:06 PM
mjperformance's Avatar
it depends where the nail is if its the tread then yes. If its in the sidewall then yes but i wouldnt because you are compromising integrity of the tire
Old 08-05-2009, 05:50 PM
meatman's Avatar
They even make plug patches!
Old 08-05-2009, 05:55 PM
jaysan's Avatar
the best way to fix it is to take the wheel of the tire and grind the inside where the hole is and patch it
Old 08-05-2009, 06:17 PM
EndlessSummer85's Avatar
I work in the auto center at sears here and those are the only sears recommended fixes are the patch plugs. We have great success with them. Just can't be in the sidewall....
Old 08-06-2009, 08:10 AM
Xsta Z 28's Avatar
Many Discount Tire Service centers would patch a tire for free.
Quick Reply: Can Tire Puncture Be Fixed?
