Fitting a 325/50/15?
Might be a lil different on a 'bird with 6.5" BS, but on my Z with 7.5" BS I needed adjustable panhard bar & LCA's, roll the fender lips, lots of hammer swinging. If you're lowered much, it's worse. I had to remove my pro-kit rear springs and put stockers back in with the isolator removed to get enough clearance on the outer lips. Of course you've got lots of grinding on the brakes to do with the 15" wheels.
How do you figure im going to blow it out?
I have stock springs with isolators removed as well. I would think on the firebird it would fit easier especially with the 6.5. I thought the only issue i would have was the lip..
Anyone else have some pics of tires they have run on this wheel?
Ty for the input tho guys.
6.5 is the wrong backspace. Even if you had the correct 7.5 backspace i thing that size tire sticks out to far for my taste. That tire is Huge with the a backspace that isn't correct i think you'll have issues. Only one way to find out mount it up and see if it'll work.
Another thing is im in school and with the wheels i would be pretty content with the car and would be calling it quits on mods for a good while.
I have a wet kit some sfc a few other things to install and ill be done. One less thing to spend cash on and one less thing taking up school time you know?
I really would like to find someone who has ran what i have.
Im pretty sure the stock suspension peices would work right? the only question will be when launching and the lip rubs correct?
The goal is too hook a with the spray. Its a bolt on car 4.10's 3800 stall and a nx 150 wet kit.
You think the 275 will do it? I really would like to do the bigger tires. Looks but also i think they will make a big difference trying to hook on the street with the bottle.
Camaro396 well at least where in the same boat lmao
Just get a good tire. You could have a huge street tire and suck on launch. When people swap over to a drag radial, they think they need a bigger tire than they really do most times. You don't have to go huge to hook, just learn how to launch and you will be fine.
Also another reason for the bigger tires was being able to stick with a 555r rather than going to the mt to help with tread life because i really dont track it much i pretty much race one the street ( no judgments or speeches needed)
Good freakin luck with that. Most of the people on here know how stupid it is to race on the street. That said though, the nitto hooks alot better on the street than the mt would or the nitto would at the track. Reverse it though, your gonna get better hook at the track with the mt when you do go. I think you would do fine on a 275/60, if you need a 28" tire. If not, go with a 275/50.
