What advantages of running a taller tire??
Old 07-28-2009, 09:49 AM
03 BUSA's Avatar
Default What advantages of running a taller tire??
Say a 28 instead of a 26.5. Is it just for more mph/rpm or do you gain more traction from a larger tire as well? Also, what are the pros/cons with a 10.5 to a 11.5 width tire. I am trying to find out if the 26.5 is what I need or am I better off with a larger/wider slick. Not so much for mph for trapping but for hooking. Thanks for the help.
Old 07-28-2009, 10:36 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Larger diameter will have a slightly larger contact patch on the ground. Most people up the diameter to change the overall gearing ratio. Lets say you have 4.30 gears and are hitting the rpm limiter in 4th gear before you cross the finish line with 26" tires. If you go up to 28" tires, you effectively reduce that 4.30 ratio and can carry more mph with the same rpm.
I would not recommend upping tire diameter until you need it. If you can hook on 26s and finish in 4th gear, you are just fine as-is. On the 4th gen f-body, figure you'll need around 128-130 mph trap speeds and 4.10 gears to use 28s.
Old 07-28-2009, 12:43 PM
03 BUSA's Avatar
I am spinning to atleast 7200 so the trap speed is not the issue. I am thinking somewhere between 128-132. So it sounds like I should stick with the 26.5 tires over the 27 then. Even for a 6sp car??
Old 07-28-2009, 12:56 PM
bluehawk2's Avatar
You will run faster on the smallest tire that you can hook on.........................as far as tire width vs sidewall, more sidewall is going to get you better traction than a tire that is wider, but with less sidewall.
Old 07-28-2009, 02:25 PM
03 BUSA's Avatar
So at the end of the day would you go with a 26.5 x 10.5 or 27 x 11.5?? Also, what are the opinions on tubes for very light street use??
Old 07-28-2009, 05:21 PM
sr71's Avatar
at the end of the day, the taller, wider tire will always hook better. not just from the wider footprint, but because the increased flex of the taller sidewall cushions the torque shock on the launch. and with the combo in your sig and a 6spd, you will need all of the traction you can get. a smaller tire may hook your car on a well prepped track, but spin like hell on a marginal track. it's always better to have more tire and not need it than to not have enough.
the key to being fast on a larger tire is to run as much tire pressure as you can and still hook.
Old 07-28-2009, 06:44 PM
03 BUSA's Avatar
Thanks guys.
Old 07-28-2009, 09:18 PM
97' Formula's Avatar
they make a 26x11.50 thats what i would go with
Old 07-29-2009, 02:49 PM
03 BUSA's Avatar
^^^I am already thinking about that one. Thanks guys.
Old 07-29-2009, 09:06 PM
TireSm0ke's Avatar
On a street tire you'll have a softer ride... If your talking about a DR or full slick you'll get a better contact patch especially if you run the right tire pressure, the lower the pressure the more contact you will get (obviously there are exceptions here). At the track I'd go with a taller tire over a wider tire simply because of weight benefits as well as gearing. What size wheel are you running?
Old 07-30-2009, 04:04 PM
03 BUSA's Avatar
15" wheel.
Old 07-30-2009, 04:05 PM
03 BUSA's Avatar
And we are talking about a bias by tire. Not a radial. I won't even consider a radial tire for an M6 at my power level.
Quick Reply: What advantages of running a taller tire??
