tire fitment or suspension issue??? please help
Old 02-18-2010, 12:14 PM
SlowAss93LT1's Avatar
Default tire fitment or suspension issue??? please help
I have about 2" to play with before the rear tires hit the fenders. I am running 27x11.5x15 tires and LOVE the look of them but I'm afraid they are too tall. The car is lowered 2" so I am rubbing if it hits a little bump or I get on it. How do I make the rear suspension extremely stiff so I dont hit the fenders? I even thought about making my own custom bump stops to prevent these from hitting.
I have 2 choices.... I am selling these tires to a friend no matter what. I am either buying 2 smaller tires, and keeping the suspension the way it is, or buying new tires the same size and making the suspension stiffer. I am not sure what I would do. Please help. I would like to get stuff ordered soon.
Here is my clearance issue:
Old 02-19-2010, 12:02 PM
anyone?
Old 02-19-2010, 12:10 PM
bigj2717's Avatar
Are your fender lips rolled? Also you cold change out the rear springs to a taller or stiffer spring. Most lowering springs are not the best if the car is more of a drag car. Oh yeah just thought of another option get a set of air lift bags to put in the springs
Old 02-19-2010, 12:24 PM
sujomatt's Avatar
what springs do u have???? i have BMR springs with essentially a 28" tire.. and its not nearly that bad
Old 02-21-2010, 03:48 PM
I was told they were eibach prokit springs. They appear to be much lower than that.
I am very tempted to put stock springs back on it.
Old 02-22-2010, 08:28 AM
BMR Tech's Avatar
Does it rub evenly on both sides?
Are the fenders rolled?
With that large of a tire the rear end will need to be centered perfectly to keep it from rubbing.
Old 02-22-2010, 11:32 AM
Both sides rub the same. The fenders are not rolled.
Old 02-23-2010, 01:21 PM
BMR Tech's Avatar
Do the tires only hit when the car launches?
The car should not "squat" at all on the launch if it is I would recommend a set of control arm relocation brackets.
The listing for the relocation brackets can be found HERE
