any one run 345 40 17 on 11" rims ( pic ) ?
Old 01-08-2011, 02:19 PM
same o'j's Avatar
Default any one run 345 40 17 on 11" rims ( pic ) ?
just want to make sure if it will fit with no problem
i have TTII 11" and would like to buy 345-40-17
but i'm wondering if there is any problem
thanks
Old 01-08-2011, 03:54 PM
carlos64030's Avatar
Pretty much everyone will tell you that you'll need at least a 12" wide wheel to run that size tire.
Old 01-08-2011, 11:21 PM
hitmanws6's Avatar
there was a thread not too long ago with some guy running it
Old 01-08-2011, 11:23 PM
westtexasbuff's Avatar
Or 11.5"
Old 01-09-2011, 08:26 PM
SHovV's Avatar
'Trust' had 345's on a 17" rim, but they were 12" wide
Old 01-10-2011, 10:44 AM
LS1RedZ's Avatar
I had a friend that ran them with no problem on I think a 10.5" wheel. The only bad thing was that the whole contact area of the tire wasnt used because they bulged out to much.
Old 01-16-2011, 10:26 AM
PONTIAC SLP's Avatar
hmmm good idea that would give aggressive look .
Old 01-19-2011, 10:09 PM
98mysticZ's Avatar
i have run the 335-35-17 hoosier drag radial on a 11in zr1
Old 01-20-2011, 09:12 PM
airforcemanss's Avatar
wow...i just bought some tt2's today from a local 17x11 and i'm in the same boat as u. the m&h drag radials 325/45/17 is what i want. i'm not sure if you have to mess with the bumpstops though. BFH and fender rolling will be required for sure.
Old 01-20-2011, 09:42 PM
tbird31's Avatar
no that's dumb.
I could see someone running 325s, some even 335s with a good bulge, but jesus 345s...just buy the right freaking width rim.
Old 01-20-2011, 10:35 PM
fccs's Avatar
Yea 345 is really pushing it lol. 325 is fine, 335 as said above Is doable and I would probably run them also if I had them. 345 is really pushing it though, that's like putting a 315 on a 9inch rim. It's going to bulge alot and probably most of the contact area will be wasted.
Old 01-21-2011, 10:16 AM
LS1RedZ's Avatar
Thats the tire Im running on my 11" Street Lites. They fit perfect IMO.
Old 01-26-2011, 01:53 AM
okay so let me say if want to run 345 for rears what is requirs for this setup ? I think adjustable panhard and some suspension parts ?
Old 01-26-2011, 08:57 AM
meine96ws6's Avatar
why is everyone set on running incredibly wide tires?
Old 01-26-2011, 09:09 AM
blackls1ta00's Avatar
^maybe there running 500 plus hp and not getting traction that would be my guess.its also that way with my car with 500 at the wheels an using mickey ts spinning at 40 mph.
Old 01-26-2011, 09:32 PM
Camaro396's Avatar
I run 345/30/18s on 18x11s just fine, without a crazy amount of bulge.
Old 01-26-2011, 10:26 PM
Hmmmm... that doesn't look bad at all.
Old 01-27-2011, 07:32 AM
Trl_ws6's Avatar
That looks perfectly fine for me, maybe no one has tried a 345 on 17x11 so is making the assumption it won't work....
Old 01-29-2011, 09:45 PM
fccs's Avatar
That ****
Old 01-29-2011, 09:53 PM
I guess it also depends on which brand of tires you're running too as some run wider or narrower than others.
Quick Reply: any one run 345 40 17 on 11" rims ( pic ) ?
