Should I with 315 or 335 for rear.
Old 12-13-2011, 12:44 PM
frack's Avatar
Default Should I with 315 or 335 for rear.
I currently have 17 x 9.5 TT2's all the way around. I have ordered some 17 x 11's and I am on the fence about what size tire to go with. My Z28 is stock height and stock suspension. I want them wide. No sense in making the change in the rears and get something thats not much different than a 275/40/17, especially considering you will no longer be able to rotate the tires. I understand the GSD3's are the widest and they no longer make them? I not concerned with doing BFH mod. Never had to roll fenders before. This would be a first on that, but I am confident it can be done. Either with a tool or old school ball bat. Don't care what that looks like considering its going to be behind the tire. Has anyone done 335's with 17 x11 tt2's on stock height and suspension. The TT2's are 44mm offset with 7.75 backspacing. Anyone have pics of TT2's on a 335 tire. Sway my decision. Help me find the right size. Edit for the subject title "Should I go with a 315 or 335 for rear." Guess I should have been paying attention while I was typing.
Old 12-13-2011, 01:09 PM
Captain Double Post
BOBS99SS's Avatar
Stock height I don't think you will have to roll.if you ever do roll fenders it is so worth it to rent the tool.I think you should be fine on stock springs.hammer mod might have to be done.but I would for sure think about lowering it, makes these cars look so much better
Old 12-13-2011, 01:11 PM
firemech21's Avatar
I vote 335s. I love the tires I put on the back of my T/A.
Old 12-13-2011, 01:55 PM
frack's Avatar
My previous car was 1997 trans am WS6. I miss that car. Loved the *** end look. The T/A's look so much better with a thick *** tire behind it. Anyone have pics of a 335 on a 17 x 11 TT2? Prefer a camaro but, a T/A is fine too. Post it up.
Old 12-21-2011, 07:19 AM
69TA's Avatar
do a search for 335 tires
there are a lot of *** shots out there
Old 12-21-2011, 07:22 AM
camaroboy14's Avatar
Do 335s
Old 12-21-2011, 08:57 AM
whitdog54's Avatar
335s all day if your staying on stock ride height.
Old 12-21-2011, 10:10 AM
NVR_SPDS's Avatar
Heres a couple pics for reference:
Left: 315/35-17 NT555 on 11" wheel. Right: 275/40-18 on a 9.5" wheel
Then the same 315s mounted on my WS6.
You wont be disappointed even with a 315.
Old 12-21-2011, 10:21 AM
BrianSF-GA's Avatar
x2 ... but, then again, the 335's look great too. It is all in how much you want to spend or, if you are like me, what kind of "deal" you can find.
Old 12-21-2011, 05:26 PM
aquariussuperman's Avatar
It is amazing that a 335 can fit on the back of these cars!
Old 12-28-2011, 05:22 PM
Posi's Avatar
17x11 and 335's you will definately be doing BFH.
Old 12-28-2011, 05:46 PM
carlos64030's Avatar
When you take into consideration on how big these cars are, it's really not all that amazing, to be honest. Not to mention that you can't just throw that wide of a wheel and tire on and make it look right without some major modifications. There are a few people here that have put wide wheels and tires on their cars without any mods, but the tires are sticking outside of the fender almost 2 to 3 inches with the ***-end jacked way the hell up. Maybe some people like that look, but I personally think it looks like ***.
Old 12-28-2011, 06:08 PM
TruBloodTransAm's Avatar
Did you have to do the BFH mod or anything to make them fit properly? Is your car lowered? Rolled fenders?
Old 12-28-2011, 10:29 PM
f-body.cbct's Avatar
If your not worried about money or doing the mods to support it id go with 335s.
Old 12-29-2011, 07:23 AM
BrianSF-GA's Avatar
OP ... also keep in mind that the T/A's rear wheel wells are slightly larger than our Camaro's. You will also be removing the bump stops if you want to jack the rear by conventional methods with the jack and jack stands placed under the frame/SFC's, otherwise, you will have to jack from the "pumpkin" and place jack stands under the axle. This doesn't work for me since I run a Drag Bar that is mounted directly under the centerline of the axle tube ..... so no place to place jack stands.
Old 12-29-2011, 07:36 AM
02ws.sik's Avatar
335!!! Those are gonna stick out. Your gonna need a big ****** jack-hammer!
Old 12-29-2011, 08:31 AM
82cetuner's Avatar
OK what about 335s on a 1.2 inch lowered T/A
I currently have it at stock height with 315s on it and had to do NO mods.
with a BFH mod and rolled fenders will 335s fit?
I have 11 inch TT2s also
Old 12-29-2011, 01:39 PM
VinR1's Avatar
Wheel offset has a lot to do with fitment too
36mm offset 17x11 ZR1s, unusually wide 315 BFG KDs, lowered 2"r 2.25"f, NO BFHing whatsoever, fenders rolled, adj phb
Old 12-29-2011, 05:47 PM
frack's Avatar
Got the 17 x 11 rims today. Damn, they look huge. 44mm Offset and 7.75 backspacing. Just looking at them I am thinking "BFH". No tires yet. Still on the fence about what brand tire. Definitely a 315/35/17. Kumho or Nitto's!
Old 12-29-2011, 07:35 PM
Uwilllosetomy93lt1's Avatar
So, are the 44mm offset recommended for a better fit? Or are the 38mm offset preferred? Not sure, but the 44mm will sit deeper inside, right, or is it the other way around? Gonna get mine black, then send them out to my local powdercoater to finish them off done entirely in black.
Quick Reply: Should I with 315 or 335 for rear.
