Bogart's on the street
Old 05-17-2012, 12:01 PM
Travu25's Avatar
Talking Bogart's on the street
I am looking at bogart's, I like several wheels they make! I have been reading on here that they are not really for the street... what makes them not for the street? Of course going around corners fast with skinnies is never a good thing to do, but what else?
Old 05-17-2012, 12:34 PM
Rise of the Phoenix's Avatar
My guess would be because they are so lightweight, street use could cause them to bend. I'm pretty sure they make Bogarts for street use. I was on their website not too long ago. There are a few guys on here running 17.9.5 and 17x11 Bogarts and run them on the street.
Old 05-17-2012, 12:42 PM
Travu25's Avatar
True, I mean like i plan on taking it so the strip often but i don't want to keep changing wheels and tires.
Old 05-17-2012, 12:48 PM
I think the 17x9.5 fronts and 17x11 would work great for both street and strip, but if stip is the emphasis, then go with 15 inch in the back. I think the D10's look pretty sick, especially in the 17 inch combo. 223Hawk used to run them.
Old 05-17-2012, 01:13 PM
Travu25's Avatar
I do too dude! I like the D10's and the RT's
Old 05-18-2012, 07:33 AM
BAMALS1's Avatar
I had force 5's once and broke two fronts and drove as careful as I could. Didn't matter still broke two fronts and payed like 150.00 each time to fix them. Badass looking wheel and they are the lightest but definitely not for the street. Never had a problem with the rears though. Maybe you can have better luck with them but like I said I was well aware and cautious about them.
Old 05-21-2012, 09:06 PM
223HAWK's Avatar
Iv got a set that I run on the street a lot. Probably more than I should, but mine were built to do so. Talk to SJM manufacturing..Steve can help you out a lot. I just recently got two 15x4s just for the track for weight savings vs the 17x6 I use to run. You cant run a drag race only wheel on the street and expect it to last. My fronts are a Road Race wheel and the rears are a street/strip wheel. They do weigh more but not enough to worry about. I know they are built better and will last...
Old 05-21-2012, 09:19 PM
Travu25's Avatar
Thanks dude. I only care about what they look like, and i can run a skinny in the front, and some sort of 10 inch tire in the back.
Old 06-15-2012, 08:37 PM
ZeeTwentyFate's Avatar
i have a set of Rts forsale here in VA wheels/tires
Old 06-15-2012, 09:35 PM
Travu25's Avatar
Thanks dude, but im going with a different wheel setup
Old 06-15-2012, 11:12 PM
THEE PEWTER Z™'s Avatar
i had a buddy who rolled around on the D10s for awhile but one day on the eway the right rear hub broke from the wheel itself . granted those rims had alot of hard hits on them on the street . your call bogart made it right and paid for damages
Quick Reply: Bogart's on the street
