DD with drag radials?
Old 07-22-2013, 07:32 PM
hogwild87's Avatar
Default DD with drag radials?
Needing to run a 305/35/18 in the rear of my c5 for the z06 rims I just purchased and I'm wondering if anybody daily drives there car with drag radials on the rear? And if so what kinda mileage can u see out of them, looking at the mt et street radial II's. I ordered 275/40/17 nitto 555's for the fronts but I'm not really wanting the 555R's for the rear considering I've heard they suck lol and they're only 25 bucks cheaper a tire over the mt's
Old 07-22-2013, 08:25 PM
GMC5.3's Avatar
Running nto5rs but I've only put about 50 miles so far, Mae sure you sty in the mid 20's as far as psi. There are a few threads on people getting 3 to 4 thousand out of the nittos, streets might be a different story and way less from what I remember
Old 07-22-2013, 08:29 PM
Kingc8r's Avatar
LS1Tech 10 Year
I run Toyo Proxes TQs, they wear just as good as Nitto 555r but hook a lot better. I've put 14k miles on them and they still have a decent amount of tread. I've been to the track with them and have done some burnouts and dig runs as well.
I bought 2 315/35/17s for $385 shipped. I'll get them again but may go to a 305 since they are way wider than my 315 Nittos before them and rub some....
Old 07-22-2013, 08:44 PM
hogwild87's Avatar
I have a set of toyo tq's in 275/40/17's I was running on my drag pack set on some front 17" z06 wheels and they didn't hook that well to me in comparison to the mt et street radials I had before
Old 07-22-2013, 08:51 PM
lemons12's Avatar
Nittos here... 315/17
Drive the car every day. They do pretty good in the rain, only time I have a problem is when it comes a flood I have to slow down.
They hook amazing... I nearly dead hook from a 20 roll without heating... If I heat them up it barely spins them over.
From a dig they also work great, I don't have traction issues by any means.
408 car so it is making power/tq.
lemons12's Avatar
I run them at 26-27 PSI all the time.
Old 07-22-2013, 09:06 PM
Kingc8r's Avatar
LS1Tech 10 Year
Depends on mods, auto vs m6. I'm under 400hp so they hook pretty well, they spin a tad from a dig.
MT ET Streets are a whole different animal and wear a lot quicker than the Toyo so it makes sense why they hook better.
Old 07-22-2013, 09:13 PM
hogwild87's Avatar
Right now my car is making 340hp/350tq at the rear on motor but I'm spraying 150 shot at the track, doing a cam swap this weekend so hoping to hit that 400 mark
Old 07-22-2013, 09:16 PM
Super Hulk Smash
JakeFusion's Avatar
Toyos are probably a nicer tire than the NT05R or MT ET Street Radials on the street.
With that said, they are a bit of an upgrade over the NT555Rs. So I'd consider them and the NT555Rs first.
Then I'd look at the NT05R or MTs.
Another option is the Toyo R888s... You won't have any flex when handling. They are a sticky road race tire that's better in the wet than all of them.
I have NT05s now and they handle well but don't grip. They do look awesome tho. I might get the NT05Rs to have matching front and rear...
But, I'm probably going to give the MT ET Street Radial IIs a go in 315/35-17. They have an actual tire pattern, so they might be decent on the street. And they probably hook the best of all 5 tires mentioned.
Old 07-23-2013, 10:32 AM
Streetlegal?'s Avatar
I have toyo R888 on all 4 tires. 275/35R18 up front and 315/30R18 out back. I love how they grip in the corners but I have no problem spinning them in first through third. Mods are in my sig. 4.56s probably don't help though.
Old 07-23-2013, 10:51 AM
Super Hulk Smash
JakeFusion's Avatar
I posted this in another thread last night:
The issue of Super Chevy had a 275 NT05R cutting the same times as the 315 MT more or less with the same 60 foot. It's just the NT05R needed less air pressure and more of a burnout to do it. Armed with that knowledge, it seems like the MTs would be better on the street: more traction with less heat and higher air pressures.
Old 07-23-2013, 10:56 AM
Detoxx03's Avatar
I run 345 NT05R's on the rear and NT05's on the front. Car isn't a daily but this combo is nice and if caught in the rain it's not bad.
If I were you I would get the R888's. If they were made wide enough for my car I would run them cause I love taking corners.
Old 07-23-2013, 10:58 AM
Super Hulk Smash
JakeFusion's Avatar
How are the NT05Rs in the corner? Pretty skittish?
Old 07-23-2013, 03:09 PM
hogwild87's Avatar
So I'm debating now between et street radial II's, toyo tq's , or 555r's or 888r's. cheapest and best traction and decent wet handling if needed what would y'all run
Old 07-23-2013, 03:20 PM
Super Hulk Smash
JakeFusion's Avatar
555R or 888R would be that.
Too bad Nitto doesn't make the 555RII anymore in 275/40-17. That'd be great to run on all four tires for cheap.
Old 07-23-2013, 03:44 PM
hogwild87's Avatar
Well I'm goin to be running a 305 or 315 35 18 in the rear and the toyo tq's are the cheaper of the the 4
Old 07-23-2013, 03:47 PM
Detoxx03's Avatar
They are fine. Obviously not like a R888 or Michelin Pilot series but a huge upgrade over the mt's.
Old 07-23-2013, 04:20 PM
Super Hulk Smash
JakeFusion's Avatar
Nitto NT555RIIs are available 305/35-18.
I would do that. It'll hook like the 555R, last a while, be good in the rain, and will handle very well.
Good to know. I'll have the NT05R in 315s coming. Once they wear and the 275 NT05s I have wear, I'll put the R888s on there.
Old 07-23-2013, 04:30 PM
hogwild87's Avatar
Don't the 555rII's have stiffer sidewalls though since they're made for auto cross and won't help me at the track?
Old 07-23-2013, 09:54 PM
hogwild87's Avatar
Just ordered the 555r's from tirecrazy.com for 576 shipped for the pair, was goin to go with the toyo tq's til I saw that the nittos has a 100 tread wear rating at least where as the toyos had none, that and I wanted to match my 275/40/17 555's up front
Quick Reply: DD with drag radials?
