02 Fbody 3" narrowed rear what backspacing?
Hey guys I have an 02 transam with a new 3" narrowed rear About to go in. What backspacing should I get on the wheels? I will be running 15x10 rims, not sure on tire yet but I do not want to roll the fenders.
Let me know your thoughts please.
Thanks!
Thanks!
LS1Tech Premium Sponsor
The 275s and 295s as mentioned will work well for what you are doing. The LCA is usually the limiting factor in clearance. We can set you up with a set of LCA that have offset bushings to help that matter if need be.
https://ls1tech.com/forums/wheels-ti...uote-pics.html
you'll find good info in this thread.....it helped me figure my backspace with 2" per side and 17x11 street lites.....personally i like the rears tucked in a little, some like them out even with the fenders
https://ls1tech.com/forums/wheels-ti...uote-pics.html you'll find good info in this thread.....it helped me figure my backspace with 2" per side and 17x11 street lites.....personally i like the rears tucked in a little, some like them out even with the fenders
LS1Tech Sponsor
Weld RTS here 15x10 with 4.5" BS. 3" narrowed per side. MT 275 Pro's. Fenders previously rolled, I love the fitment and it tucks up nicely but needs the rolled fenders.
Pictures are worth a thousand words!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I have a rear narrowed 2" each side. I run a weld rts with 6.5" bs, looks nice and tucked, I bought Tt2s 17x11 with a recommended bs of 5.5" and it stuck out to much. I'd go 5.5" bs on a -3" rear.
Superman09 what is the biggest wheel you see fitting? Im getting narrowed rear 3" but would like to run a 325 or at least a 295.. I see yours sits Exactly how id want mine but is a 275. Btw when is my twin v2 kit going to be done
LS1Tech Sponsor
I could maybe squeeze a 295 on there. 325 is too much IMO and unnecessary.... I have seen this 275 ET Pro hook way better than a 325 MT DR on the same car.
__________________
