Help!.....wth do you use on clear coated c6 rims!
Old 07-02-2015, 05:55 PM
greenls1owner's Avatar
Default Help!.....wth do you use on clear coated c6 rims!
bought the weblys rags at amazon and some adams polish....I had no idea these wheels were clear coated......what are u guys using? I think I made them look worse, maybe cloudy with the adams polish ;(
Old 07-03-2015, 12:34 PM
bigbomber5's Avatar
I was just wondering about this same issue concerning my TA's wheels. Since they are clear coated can a compound like Meguiar's Ultimate Compound be used effectively on them? Im probably going to strip mine soon with aircraft stripper like a lot of people on here have done.
Old 07-03-2015, 03:29 PM
Double-aught_Z/28's Avatar
Before I took them off, I just used soap and water on my WS6 speedlines. Just wash them regularly. I suppose you could wax them.
Old 07-04-2015, 12:42 AM
The Guz's Avatar
If they are clear coated then treat them like paint. Try a test spot with some polish and see how it looks. If you need more correction then step up to a compound. You can use the same sealant you use on your paint.
Adams Quick Sealant lasts about 3 months. It's going to be phased out shortly due to VOC's. Meguiar's has brake dust barrier but that has been discontinued. That is more durable than Adams.
If you really want the ultimate protection you can invest in a coating. Detailer's Pro wheel coating is affordable.
Old 07-04-2015, 10:19 AM
badfbodyz's Avatar
They will never be as shiny as getting aircraft paint remover and stripping off the clear. That's the way to make them really shine. But, be prepared to polish that aluminum more often. Worth it IMO
Old 07-04-2015, 12:51 PM
The Guz's Avatar
Keep them sealed and you shouldn't need to polish as often.
Old 07-06-2015, 09:45 AM
thanks guys.....I tried the adams on two of the wheels..and it really didn't do much...obiveouly more made for un coated wheels....im not sure if I want to strip them or not at this point...living in this part of the country are roads get hammered....this aint no trailer queen, it gets driven..lol
Old 07-06-2015, 11:38 AM
The Guz's Avatar
Which adams products did you actually use?
Old 07-06-2015, 02:13 PM
adams 1 spokes are decent....webbing is cloudy....rims came off a 8,000 mile car.....thinking that gm's wheels just suck
Old 07-07-2015, 10:56 PM
badfbodyz's Avatar
Wheels don't suck...lol. Underneath that shitty clear, is shiny aluminum.
Old 07-08-2015, 12:19 AM
The Guz's Avatar
If they are starting to do this, then the clear coat has failed.
https://ls1tech.com/forums/wheels-ti...h-out-pic.html
No polish will remove that.
Quick Reply: Help!.....wth do you use on clear coated c6 rims!
