help, no lug nut key!
Old 12-27-2004, 02:01 PM
93ZM6's Avatar
Default HELP ASAP!!! No lug nut key
Well I ran over a screw a little while back and my rear tire has a slow leak in it. Well the car came with these aftermarket rims which have a cover on them so you cant see the lug nuts right, well i was gonna take the tire off today to take to les schwab to have them patch it.
Well i got the cover off the rim and it turns out it has one of those gorilla lock nut things were you need a special key and the dealer i bought the car from never gave me one or said anything about it having one? Am i screwed how else can u get those lock nuts off? Please Please help.
Old 12-27-2004, 02:11 PM
Cyborg's Avatar
A Chevrolet dealer should be able to use a tool to break off that stud, and replace it with a new stud and nut. I've seen it done on stock wheels without damage. I think they do it from the back.
Old 12-27-2004, 06:23 PM
Nova5's Avatar
vicegrips (wide toothy ones) and a hammer! now if the outside is a sleeve and rotates... a little bit of explosives should do the trick.
Old 12-27-2004, 08:36 PM
TwoFast4Lv's Avatar
I usualy drive a T60 Torex in them and they come right off
Old 12-27-2004, 09:29 PM
93ZM6's Avatar
well looks like i can order a new one but it takes like 4 weeks for delivery damnit, oh well i still need a new optispark really bad and i think i need a new egr valve too so i dont drive the car much anywhoits miss firing all over the place
Old 12-27-2004, 10:23 PM
brandboZ28's Avatar
My first mod was the wheel key delete
Old 12-28-2004, 06:10 AM
slowmofo's Avatar
Thats how I got mine off
Old 12-28-2004, 07:19 AM
SAPPER's Avatar
Fellas, well, I guess he got it off, BUT, the proper way to remove them is with a socket that removes stripped nuts. Craftsman has the set on sale right now. They are a 6 or 7 pc set that looks like an easy out but female type. The large one will fit over most 3/4 lugnuts and you just tap the breaker bar as you're turning...voila'. I have the Snap-on set that is specifically for lug nut removal. I will never pay that much again after seeing how cheap the craftsman set is.
Also, what I don't get is why didn't the tire shop remove it? they have the tools for that.
Old 12-28-2004, 10:45 AM
TwoFast4Lv's Avatar
Actually the correct way is the correct keyed socket
Old 12-28-2004, 07:30 PM
SAPPER's Avatar
Old 12-28-2004, 07:42 PM
TwoFast4Lv's Avatar
Sorry I just had to man
Old 12-28-2004, 08:10 PM
SAPPER's Avatar
yes, that was a good bash I deserved. LMAO
It was funny though!!
Quick Reply: help, no lug nut key!
