red calipers?
Old 01-19-2005, 05:41 AM
baloga41's Avatar
Question red calipers?
I’ve painted my calipers several times with red and every time the color disappears. What is the best way to paint it so it will last longer?
Old 01-19-2005, 08:36 AM
5POINT7's Avatar
Did you clean them real good first and then sand them down so the paint will adhere. I did that and painted them once and they've looked great ever since.
Btw, that was last summer.
Old 01-19-2005, 10:06 AM
777's Avatar
clean them with brake cleaner then sand them down...use hi-temp paint...
Old 01-19-2005, 02:04 PM
BitViper's Avatar
or buy a set of these...
http://community.webshots.com/photo/...62174353YUJtRM
or these...
http://community.webshots.com/photo/...65488827TJVSRw
Old 01-19-2005, 02:19 PM
Xsta Z 28's Avatar
What do you mean the color dissappears?????
Old 01-19-2005, 04:35 PM
Ptvolly's Avatar
What kinda paint did you use? I just bought a dupli-color kit from wal-mart but gotta wait till it gets a little warmer around here.
Did some reading in the handling/brake section and it seems the biggest factor is prep work.
Old 01-19-2005, 05:03 PM
5POINT7's Avatar
If it helps, I painted mine with "caliper paint" from AutoZone. Forgot what kinda sandpaper though.
Old 01-19-2005, 06:53 PM
musclehead's Avatar
I agree with 5.7, prep is the most crucial part take your time and do a good job. I suggest removing the calipers it makes the whole job alot easier. That's what I did and did it once, everything is holding up just fine.
Old 01-19-2005, 09:51 PM
Casperws6's Avatar
when i painted mine i left the calipers on. I got a plastic bag and covered the rotors. i sparyed, very little for my first coat on the caliper. waited till it dried, then i sprayed a second coat and so on. took me about 3-4hrs to do it. It's still there. btw, i used caliper paint - good to 900 degree's i believe. Good luck
