Firestone Fuzion Tires
Old 03-04-2005, 02:50 PM
silver30th's Avatar
Default Firestone Fuzion Tires
okay, i really need some cheap tires and i found these at a local dealer, pretty good looking tread pattern and a decent price at 136 a peice, mounted and balanced.
anyone running these? your thoughts on them?
thanks
Old 03-04-2005, 03:08 PM
hawgs's Avatar
I bought a set and have had them on my car for about 2000 miles. I really like them. Good dry and wet traction, low noise, and good ride.
Old 03-04-2005, 03:21 PM
timelord's Avatar
They are impossible to beat for the price.
They are also lightyears ahead of the SZ50 in the wet[which I thought was impossible].
In 95% of driving you will never know they aren't $$$ tires,if pushed to the absolute limits of your car you will feel more sidewall flex,again only in EXTREME cases!!!
Old 03-04-2005, 05:11 PM
00firebird's Avatar
in thoes extreme cases im sure that would happen on most all tires
Old 03-04-2005, 10:19 PM
redline2k's Avatar
They should only be better than the sz50's when new as they wear the fuzions should loss performance. The sz50 is a dual compound tire and will keep its wet weather performance longer. I do agree the fuzion is a great tire for the money.
Old 03-05-2005, 11:00 AM
AltrdPrcptn's Avatar
i have had them on for about 3500 miles and i love the tires. i can vouch for everything that has already been said. if your looking for a cheap performance tire these are the tires you should pick up.
Old 03-05-2005, 12:00 PM
silver30th's Avatar
thanks for the responses, i think (once i round up some cash) i will get these tires.
Old 03-05-2005, 01:33 PM
my98ws6's Avatar
Just to add what everyone else has said, I have had these on my car now for about 10000 miles and they have been wonderful. Very responsive in wet and dry conditions. To be honest, when I bought these at the end of last year, I was just looking for a cheap set to ride out the rest of the year on until spring. I was very pleasently suprised. Can't beat the performance for the price.
Old 03-07-2005, 12:06 PM
Gallitin's Avatar
All I have to say is I bought a set...you get what you pay for. I will never buy another set. Car doesn't stick to the road like it should. Even the *** end of the car in sharp turns slides out. I sold mine on ebay and stuck with the Eagle F1's.
Old 03-07-2005, 12:51 PM
Andros's Avatar
Im running 275/40R17 98W Fuzion Tires on all 4
Rides great
Old 03-07-2005, 02:36 PM
silver30th's Avatar
Gallitin, what problems have you had such as "not sticking to the road like it should"??
Old 03-07-2005, 02:48 PM
LSUxBlake's Avatar
I hope you bought the Eagle F1 GS-D3, cause the regular F1's suck ***.
Old 03-07-2005, 02:55 PM
Gallitin's Avatar
Not sure why, I assume its harder rubber than what I'm used to. Going into corners fast and back end of the car will slide rather then sit. Also the front end sliding when braking into a turn. This isn't driving extremly fast either. Within the first 1000 miles on the tires I had 2 blowouts and 1 crack in the sidewall. Luckly I had road hazard. But from the looks of it with everyones else's experience I could have just had bad luck.
