biggest, fattest, nastiest tires on 17" wheels
Old 04-01-2005, 04:45 PM
DragLS1's Avatar
Default biggest, fattest, nastiest tires on 17" wheels
I would really love to see some pics of the beefiest back tires that you can fit on a 17"X9.5" wheel. Who has the fattest, tallest combo?
Forgive me if there have been multiple threads on this but I have only been part of this site for a little while.
Thanks....Jess
Old 04-02-2005, 02:09 PM
LS1 Sounds's Avatar
Do you want sticky? Or just big for looks? If you want traction, try these in 275/40R17:
http://www.mickeythompsontires.com/s...et_radial.html
Old 04-02-2005, 02:16 PM
777's Avatar
yeah people will say 315's but i wouldn't do it...they just don't look right...
Old 04-02-2005, 05:06 PM
LS1 Sounds's Avatar
If you want a wide tire with a nice looking tread pattern, try the Goodyear Eagle F1 GS-D3 in 275/40ZR17. It's an excellent tire for all-around use, but it's not cheap.
Old 04-03-2005, 01:31 AM
nvrstsfd23's Avatar
285s would be nice and wide.
Old 04-03-2005, 08:48 AM
LS1 Sounds's Avatar
Trying to squeeze on a tire that's too wide for the rim could actually result in a smaller contact patch than a properly sized tire though. I've seen a 315 tire on a 9.5" wheel before and it looked odd, the same car had a 275 width on the front which made the rears look even worse.
If you want something big and tall, get some 15" Bogarts or Welds and run a 28" tire.
Old 04-03-2005, 10:37 AM
elite22xl's Avatar
my friend has 285s on his 10" rear wheels and they look perfect, maybe even a little wide, so for the 11"s i would go with the 285s
Old 04-03-2005, 11:02 AM
Moderator
davered00ss's Avatar
275's. Get BFG drag radials.
Old 04-03-2005, 08:23 PM
LS1 Sounds's Avatar
An 11" wheel needs a 315/35R17, a 9" or 9.5" needs a 275/40R17.
Old 04-03-2005, 09:22 PM
10 Second Fun Car
jlrz28's Avatar
Im currently running 285 40 17 all the way around on my TT2s. I like it!
Old 04-04-2005, 03:51 PM
peteZ's Avatar
Be careful if you're looking at Nittos - they tend to run smaller than most other tires. I'm running 315 Nitto DRs' on my 10 spokes with no problems. They are a bit wide, but IMO the 275's looked because they seemed narrower than the 275 F1's. I think they make a 295 which is probably perfect, but I didn't know that when I got mine.
You probably want to stick to 275's or 285's with most other brands though.
PM me if you want a pic of the wheel off the car w/315 Nitto DR's.
Old 04-04-2005, 06:26 PM
SlowTA's Avatar
if its an 11 inch wheel you really need to put on 315's or atleast something bigger than 275's
Old 04-04-2005, 08:59 PM
TA4U2NV's Avatar
I'm running 315's on my 11" wide TTII's in the rear I love them.
