how many "mm" are in an inch????
Old 05-13-2005, 07:42 PM
trouse40's Avatar
Default how many "mm" are in an inch????
how many milimeters are in 1 inch? i want to get some hp evo's 9 inch rears and get them widdened to 11" so that would add 2 inches to the backspacing. if the wheels have a 38mm backspacing now what would they have after an aditional 2 inches?
Old 05-13-2005, 07:50 PM
f-bodman's Avatar
There are 25.4mm in an inch.
Old 05-13-2005, 08:17 PM
trouse40's Avatar
im not saying thats wrong but that means my z06 wheels have 2 (53mm)inches of backspacing
Old 05-13-2005, 08:37 PM
TTSSZ's Avatar
No, have 2 (53mm) inches of offset.
Old 05-13-2005, 08:42 PM
Fulton 1's Avatar
That's doubtful. If you lay a straightedge across the back of your wheel and measure down to the inner surface of the hub mounting pad, then you'll have your backspacing. You may be confusing offset with backspacing...?
Here's a link that may help: http://www.rsracing.com/tech-wheel.html
Old 05-16-2005, 10:58 PM
89FormulaLS2's Avatar
Regardless of offsets and backspacing differences..............
25.4mm = 1 inch is correct.
Old 05-16-2005, 11:18 PM
evilbadz's Avatar
Google calculator is your friend
http://www.google.com/search?q=1+inch+in+millimeters
Old 05-17-2005, 04:41 PM
Eugenio_SS's Avatar
backspacing is usually given in inches.
offset is usually given in mm
backspacing and offset are not the same but are inter-related.
