295's on 17 x 9 1/2
They will fit, but they will not be optimal. Tire rack lists a 10 inch wheel as the minimum for the Kumho 710. Don't know which tire you are getting but even if a 9.5 inch wheel is listed as the minimum,,, your still not going to be using the tire to it's limit.
Saying that, I'm running a 315 on 10.5 inch wheels. Once again not perfect but it works. I do leave a bit of under used tread surface on the edges due to the tread being pulled together on the too narrow wheels. I will be dropping down to 295s on my next tire change though.
Originally Posted by Xsta Z 28
295's do not fit on 9.5" wide wheels . . . 10" minimum recommended width.
It may not be recommended, but it will definately fit. I've had 315's on the stock 9" rim for 3 months and never had any problems, no rubbing...etc on stock ride height. But I soon came to realize that 315's on a 9" rim probably wasn't a good idea, so I took them off.
Originally Posted by Evaporate
I didn't know there ever was a 295 option for a 17" wheel. All I've ever seen was the 285 skip to 315, nothing in between.
I guess that answers your question, 285's it is...
