pro stars
Old 03-13-2007, 07:17 PM
darrell hoagland's Avatar
Default pro stars
i just got some 15x10 pro stars with 7.5 backspacing will i have to roll my finder lip
Old 03-13-2007, 07:23 PM
Restricted User
GDBY2U's Avatar
Yup! And Remove The Bump Stop pad.
Old 03-13-2007, 07:41 PM
SLPSS99's Avatar
You may not have to remove the bump stops or roll the fender, it depends on the tire size you plan on running.
Dan
Old 03-13-2007, 07:58 PM
what is the biggest i can run without rolling my finder lip
Old 03-13-2007, 09:57 PM
DroppedM6Z's Avatar
I'm using the 15x10 with 6.5" BS and not one problem.
Old 03-13-2007, 11:27 PM
siniSSter's Avatar
I have a 15x10 wheel, with Hoosier Quicktime Pros 27x11.50x15's. No problems here, just bolted right up.
Old 03-14-2007, 12:00 AM
indigo28's Avatar
ive got weld draglites and i grinded my calipers down, and am running 275/50/15 for rear tires bfg/radials street tires on a 15x10 wheel, fit fine
Old 03-14-2007, 04:22 PM
1 Stout Z's Avatar
I ran 15X10 7.5bs with 26X11.5X15 MT E.T. streets with no other modifications other than grinding the calipers. No problems here.
Old 03-14-2007, 06:33 PM
thanks
Old 03-14-2007, 10:05 PM
SMOKKINU's Avatar
im having an issue with my prostars fitting... the wheel is hitting the rotor where the studs are...its like the studs arent long enough.....
did you guys have to get longer studs?
Old 03-15-2007, 06:01 AM
LS69TA's Avatar
Have you used the grinder on your calipers yet? If not, that's your problem. On the front you can run a 5/16" spacer and longer studs, but on the rear you have to grind them.
Old 03-15-2007, 06:02 AM
LS69TA's Avatar
Once you start getting into the larger tires (28"+) usually you'll have to do some clearancing to fit them.
Old 03-15-2007, 02:11 PM
SMOKKINU's Avatar
yes, the caliper is clearing fine.... the studs just dont seem to be long enough...and im wondering why some people are saying theirs went on no problems, but mine arent...
Old 03-15-2007, 02:38 PM
LS69TA's Avatar
The studs won't go through the wheel. You need shank-style lugnuts to go through the wheel. I'll try to find a pic. to show what I'm talking about.
Old 03-15-2007, 02:39 PM
LS69TA's Avatar
Here's what you need.
Old 03-15-2007, 08:56 PM
PowerShift408's Avatar
I've been wondering the same thing myself. I want to run the 27x11.5x15 tires on 15x10 pro-stars... but I am also sitting on the eibach pro-kit. I'm guessing there's definite fender-rolling in my future. What about the bumpstops though? I'm not crazy about losing them, but will if I have to.
What are the negatives to removing the bumpstops for a car that is driven on the road? How bad can it end up being?
Old 03-16-2007, 05:01 PM
SMOKKINU's Avatar
picked them up today, hope tracks open this weekend, its time to
Old 03-17-2007, 09:37 AM
LS69TA's Avatar
Cool. Hope they work out good for ya.
