best drag tires?????????
I currently have 275-40-17 BFG g-force T/A drag radials. they work pretty good for traction on the street and track. but I need more traction now. I have heard a lot of good things about mickey thompson's tires, and also seen a lot of ppl with nitto's too. I need something for the drag strip and street use. I don't plan on driving a whole lot on the street because i have another vehicle to get back and forth to work with.
So what dr gets the best traction??
MT et streets, they are only 26x10.5x16 on stock ta wheels, they hook like a mother f-er. i would not put them on your daily driver wheels, not safe. get some 16s like i did for the track, they are lighter than the 17s
the factory 17 inch wheels measure about 24-24.5 inches high, these are atleast 2 inches taller. i would not go any bigger on stock gearing either.
I wouldn't get the ET Streets for any wheel that is going to see any street use. The tires will wear out quickly & they handle like a flat tire. My vote goes for the ET Street Radial, they hook good & can be driven on without any problems.
Wrong. The MT ET Street Radials do in fact have an equal these days... The Hoosier DR's. I had the MT's and switched to the Hoosiers. From what I've seen so far it's a great tire that will hook better than the MT's. Only downside from what I can see is an increased treadwear on an already low low low mileage tire.
i only plan on driving my camaro about 100 miles a week. and not to work very often. The only time I will probably drive it is when i go crusing around town street racing or at the track. Would the ET street tires work for this kind of driving? wearing out fast is not something that i'm too worried about since my last set of BFG DR's have outlasted my expectations and that was even when I was driving it to work kinda often..
http://store.summitracing.com/partde...5&autoview=sku
mickey thompson also has a straight drag radial(non street tire) if you're considering the hoosiers.
http://www.mickeythompsontires.com/s...m=ETDragRadial
they are start at a 29" tire though.
