Camaro vs. Camaro in No Prep Grudge Match Drag Race
By -
F-Body Camaro throws down and takes the win in gnarly no prep race.
We here at LS1tech love us some no-prep drag racing. Without a prepped surface, it’s all about who can make the most of their very limited traction. It also usually results in some very nutty ‘street’ cars getting loose, and having to be reined in by their pilots.
So, when famed grudge match racer Tony V makes an appearance, we take notice. Tony V, actually Anthony Mangiaracina, is something of a celebrity when it comes to hurting feelings at the strip. His fourth-gen F-Body Camaro, at least, when we last saw it, uses a carb’d all-motor setup paired to a built Powerglide. The combination doesn’t sound too wild, on paper, but Tony V, as he is known, makes the most of it.
Tony V Camaro No Prep Grudge Match Drag Race LS1tech.com
That said, it didn’t stop this challenger, staged to the right of Mangiaracina in a classic Camaro, from trying.
Both cars start out with a burnout, surrounded on all sides by a large crowd. Pro tip: Standing behind a drag car in the almost-a-burnout-box staging area is a good way to lose an eye. They’re cleaning off the tires, and that much wheel speed means any grit on those rear tires instantly becomes a projectile. Stand clear, everyone!
ALSO SEE: Driving the Camaro SS Hybrid of the Future
Also stand clear because Tony V can barely see through his smoke show. After a bit of back and forth, the air clears and both cars roll up to the tree.
As soon as the tree goes green, things go South for Tony V’s opponent. The classic Camaro gets squirrelly off the line, and while both cars are picking up the front wheels through the 1/8th mark, it’s the newer fourth-gen Camaro, piloted by Tony V, that keeps things going straight.
Want to know more about the Tony V. Camaro? Us, too. Fortunately, our friends at DragZine got as much of an interview out of the man himself as a grudge racer will give. Check it out here.
Join the LS1tech forums today!
Jake Stumph is a lifelong car enthusiast and racer, and former content editor for Internet Brands Automotive which he joined in 2015. His work has been featured by several other prominent automotive outlets, including Jalopnik and Autobytel.
He obtained a bachelor's degree in Political Science at the Ohio State University in 2013, then pivoted from covering politics and policy to writing about his automotive adventures, something that, he says, is a lot more fun. Since that time, he has established connections with most of the world's major automakers, as well as other key brands in the automotive industry.
He enjoys track days, drifting, and autocross, at least, when his cars are running right, which is uncommon.
