Disappointing Camaro Burnout Turns Awesome
A burnout is a relatively simple operation. Mash the gas, dump the clutch, and keep the car from tearing off into the wild blue yonder with the brakes. But if you’re unfamiliar with the process, you might forget about a little thing called traction control. That little demon turned what should’ve been an awesome burnout into a weak bit of tire spin.
When he figures it out though… Well, you can guess what happens.
