Proform brushless cooling fans?
Old 06-06-2024, 04:23 PM
Kfxguy's Avatar
Default Proform brushless cooling fans?
I wasnt sure where to put this as I didn't see a cooling section..... feel free to move it if i missed it.....
Being I'm turboed, i've been running into "overheating" problems down here in the south during the summer. I say "overheating" because it runs warmer than I like, I've seen 220ish.... not cool. No pun intended.
I Built an aluminum shroud to house the fans, but I wasnt sure what route I wanted to take. I know I want brushless fans but the only thing I saw that looked good was the Deltapag fans, but it would cost me a grand or more for two fans. I don't have that kind of extra cash for those so I was thinking about buying one flex a lite 238 (16" 3000cfm $169) and a deltapag 12" with controller (2100cfm $469 yikes). I accidently came across the Proform brushless fans, but they are too new to find any feedback or reviews on them. Just wondering if any of you guys have tried them yet, Or am I gonna be the guinea pig?
https://www.proformparts.com/brushless
Old 06-06-2024, 04:42 PM
LS1Formulation's Avatar
Try them out! Lol... I'm glad they don't make these as pushers because I would have given them a try. I can't fit pullers on mine, even with my radiator stood up. I just bought a couple Flex-A-Lite Wave fans, hopefully they'll work. I'm in Michigan, it never gets super hot here.
Kfxguy (06-06-2024)
Old 06-06-2024, 05:24 PM
Man-Crush Warning
Shownomercy's Avatar
"Not compatible with variable speed fan controllers using PWM technology. Works with normal on/off thermostat controllers."
Kinda defeats the purpose of a brushless setup IMO
wretched73 (06-07-2024)
Old 06-06-2024, 08:33 PM
Kfxguy's Avatar
they sell a separate controller that will vary the speed if you desire. They are also soft start. Doesn’t really defeat the whole purpose of a brushless setup.
me having been into RC vehicles and into brushless technology, I can tell you with certainty that the main benefit is far more power output while using less amps and a motor that essentially never wears out, there’s no brushes to wear and the motor doesn’t get weaker over time like a brushed motor does.
and get this: the controller is like $43!
https://www.proformparts.com/product...fan-controller
edit: I see where it’s a manual controller. But the fans are pwm capable when using the third wire.
Old 06-06-2024, 10:25 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,167 Likes on 759 Posts
What is your current fan setup? Are you running lines to your heater core?
Old 06-07-2024, 07:13 AM
wretched73's Avatar
What is your ratio of coolant to water? 50:50?
Old 06-07-2024, 07:24 AM
wlink14's Avatar
Honestly I have heard of so many guys rave over using OEM fans from the junkyard that I think you should try them out. A trip to the junkyard should only set you back like $75.
Look for fans from a volvo xc90, ford escape, chevy traverse etc.FWD SUV E fans that will fit. They are all PWM compatible if you swipe the controller with them as well.
If you want the bling factor, I vote for the DeltaPag setup. I came across them at PRI a few years back, and they had a booth on display with a **** to dial them up. The single fan made my face flabby like I stuck it out the window at 70mph on the highway. I was dumbfounded by the amount of air they could move.
The following 3 users liked this post by wlink14:
ALL ULL C (06-07-2024), Jimbo1367 (06-15-2024), Kfxguy (06-07-2024)
Old 06-07-2024, 08:29 AM
Kfxguy's Avatar
I'm running the stock 2004 gto fans. Upgraded (cold case) aluminum radiator.
yes I have water running to my heater core.
Old 06-07-2024, 08:30 AM
Kfxguy's Avatar
I'm not sure, not much coolant vs water though. And a couple bottle of water wetter. I don't run much coolant because it usually doesn't get real cold down here.
Old 06-07-2024, 08:37 AM
Kfxguy's Avatar
If I could afford the deltapag, thats my first choice. If the proform move 20% more air than my factory fans, I'll probably be set.
Today will be the test. high is supposed to be 94, so the drive home in extreme traffic will tell me all i need to know. If it runs hot, I'll be ordering the proforms. I reached out to them to see if they would be willing to send me some fans to do a review on.
Old 06-07-2024, 08:55 AM
wretched73's Avatar
I would either use 100% water and water wetter or a 70/30 coolant water ratio, or 80/20 depending on your climate.
Old 06-07-2024, 09:01 AM
Kfxguy's Avatar
I don’t know the exact ratio but it’s barely hot coolant in it. It’s mostly water now. I’m at a point where I need a fan upgrade no matter what. There’s an Intercooler in front of the condenser and a trans cooler too.
Old 06-07-2024, 09:33 AM
LS1Tech Co-Founder
Are you running stock fan settings?
Old 06-07-2024, 11:57 AM
Kfxguy's Avatar
no. I have them coming on sooner.
on lunch right now. Washed the car, let it idle with ac on while I washed and dried it. Now headed to get food, seen 205 then it settled to 203 at the light. Driving a little more in traffic I saw 206. It’s 90f out right now and pretty humid. Yea, it’s getting fans.
Old 06-07-2024, 12:01 PM
Kfxguy's Avatar
Just for my notes. Went in picked up my food. Heat soaked to 215 then running 212 at idle. See if it comes down when moving. Trans temp is only 172.
Old 06-07-2024, 12:35 PM
Kfxguy's Avatar
Alright I just ordered a 16" one to see how hard it blows. If it impresses me I'll order a 12" one.
Old 06-07-2024, 05:31 PM
Miata khalifa's Avatar
Just installed 2 14" pro forms today. They work great, when they're both on at the same time.. voltage keeps dropping super low at idle and they won't stay on at the same time. Google brought me here, since like you Said, there's really no info on them yet..
Old 06-07-2024, 07:43 PM
Kfxguy's Avatar
why is your voltage dropping? What kind of vehicle?
Old 06-07-2024, 07:57 PM
LS1Tech Co-Founder
What _x_ area are you working with?
Old 06-07-2024, 08:22 PM
TrendSetter's Avatar
here you go I just saved you $33
https://www.ebay.com/itm/26405702562...BlBMUIqF_db-Yw
Quick Reply: Proform brushless cooling fans?
