11 Second Club Snake eyes are a good thing
11's first time out
Old Sep 14, 2009 | 09:59 AM
dmart's Avatar
Default 11's first time out
First time out Saturday ran 11.61@118 with a 1.58 60' leaving on the limiter (6650) with the tires at 11psi. DA was right around 2400. Mods are:
cam only 228/232 110
mwc 9" 4.56
textralia clutch
28x10.5x15 et drags on billet spec street lites
decent amount of weight reduction
ms 5pt
strange sa front shocks
comp eng rear shocks
I'll post the slip later I don't have it at work with me.
Old Sep 14, 2009 | 11:30 AM
OOOJOHN's Avatar
thats awesome hit it with some spray you will be deep in the 10's
Old Sep 14, 2009 | 01:43 PM
Intercooler2's Avatar
Not too bad first time out.
Old Sep 14, 2009 | 08:52 PM
LT1Formula007's Avatar
Congrats on the 11 second pass!
James
Old Sep 14, 2009 | 08:54 PM
therobman's Avatar
niceee
Old Sep 19, 2009 | 03:56 AM
camaro_best's Avatar
nice run
did you lowered the car?
Old Sep 19, 2009 | 09:53 AM
speedshifterNC's Avatar
were you on the limiter going thru the lights?
Old Sep 19, 2009 | 10:20 AM
MelScrilla's Avatar
mwc 9" 4.56
textralia clutch
ms 5pt
I was wondering what kind of times that cam would post. that would probably put a full weight car with a auto right at 11.9
Old Sep 19, 2009 | 11:30 AM
dmart's Avatar
Originally Posted by camaro_best
nice run
Yes
No, mathematically I should be able to go about 123 with the current limiter and that doesn't take into account tire growth.
Old Sep 22, 2009 | 08:29 PM
Yes
How much in the rear you lowered ?
Old Sep 22, 2009 | 09:06 PM
DTB_LS1's Avatar
Nice time, we have very similar setups. I ran a new PB on 9/12/09 which was 11.64@118 with a 1.62 60'. My cam is 231/237 and I was launching at 5800. I'm going back on Oct 24th to shoot for 11.5s. How much does your car weigh and what weight reduction do you have? Great looking car btw!
Old Sep 22, 2009 | 09:12 PM
Magnet's Avatar
good run!
Old Sep 23, 2009 | 12:12 AM
TORCHD 02 TA's Avatar
hmm nice run.. I have the same cam, same clutch and i was on M/T DRs on my stock 10 bolt and ran an 11.8 @ 119
I sooooo need a 12 bolt
Those tires are too big for your car. Unless in the future you are going with a PA.. You should stick with a 26" tall tire.. How much RWHP are you making? With all the mods in my sig, I am making 419... Put on a 26" tire and you will run faster
Old Sep 23, 2009 | 10:30 AM
dmart's Avatar
What was the DA?
I'd rather overtire the car than undertire it, plus I plan on either a big h/c setup or a stroker if the motor lets go. If I go with a 26" I won't have enough gear on the big end. But you are right it's too much tire, leaving on the limiter it was bogging Thinking I'll tighten up the front a bit (was pulling them) and put a couple psi back in there. Perhaps bump up the limiter to 6800 judging by where you make your power.
I'm going back this weekend with some changes, wanna go 11.4x or break it trying.
Any idea what your car weighs?
Old Sep 23, 2009 | 10:44 AM
dmart's Avatar
All the HVAC stuff is gone, no back seats, no passenger, ozite carpet, kirkey seat, you get the idea. Then all the safety stuff to go 10.0, steel 5 point, loop etc. No idea what it weighs though.
What was your tire pressure at? I was going down in increments of 1 all day starting at 20 and couldn't hook. Some dude (running 8.50's) comes by on his atv and yells 'get those f*ckers down to 10' I laughed and and aired down to 11, next pass it ran a 1.55 60' pulling the fronts
Old Sep 23, 2009 | 11:31 AM
PowershifterNC's Avatar
I think you found my problem...I'm leaving on 13 psi but only launching @ 4500...leave on the limiter huh?
Old Sep 23, 2009 | 11:36 AM
dmart's Avatar
Do it, it feels oh so good. Made me more consistent too cause I could just WOT and dump the clutch.
Old Sep 23, 2009 | 12:07 PM
DTB_LS1's Avatar
I was around 10-10.5psi cold. I'm going to start start out at around 11psi nextime out and work my may back down. I'm also going to bump the 2-step up to 6000 and work my way up. I really believe my car will go 11.5s or better.
Old Sep 23, 2009 | 12:14 PM
dmart's Avatar
How's your t56 treating ya? Synchros in mine are starting to get bad. Trying to decide if I should just do a standard rebuild or faceplate it. I'm losing a lot of time on my shifts ;[
Old Sep 23, 2009 | 01:22 PM
if you're gonna race alot don't waste time with a standard rebuild...thats just one more thing to worry about...reason I haven't left on the rev limiter is I'm worried about the stock bellhousing. Bought the car as a driver now I'm building it into a street strip car even though I already have a strip car...I have the sickness..lol
