V6 Turbo S10 Ran 11's!
I know this isn't an LS1 or LS anything, but thought I would share anyway.
Turned up the boost a couple pounds from last time out and ran a lot faster than I was expecting. My previous best run was 12.2 @ 114 with 14 psi or so.
Stock long block 4.3l vortec V6
GT3582R turbo @ 16 psi
4L60E trans with shift kit
Running e85
Tuned by myself with hptuners
Instagram @turbo_v6
Timeslip info:
60 FT - 1.7943
330 FT - 5.0121
1/8 ET - 7.7099
1/8 MPH - 93.73
1000 ET - 10.0116
1000 MPH - 106.79
1/4 ET - 11.9390
1/4 MPH 117.86
Also took it to a dyno day the next day and put down 356whp and 450wtq @ 13.5 psi
Video of the run:
I love this little truck and I can't wait to see what I will do with it next.
Running e85
Instagram @turbo_v6
Timeslip info:
60 FT - 1.7943
330 FT - 5.0121
1/8 ET - 7.7099
1/8 MPH - 93.73
1000 ET - 10.0116
1000 MPH - 106.79
1/4 ET - 11.9390
1/4 MPH 117.86
Video of the run:
Big torque down low was what I expected. It would be great to put a cam and ported heads on it, but I'm not sure how far I want to take it.
That's what I get for not paying attention. Anyway, that's a torque monster for a v6.
I'm confused by your apprehension to cam it... you've already turned an s10 into a turbo drag truck. Why not put the right cam in there? It doesn't need to be some high lift monster cam--just something that doesn't peak at 4500rpm and can take advantage of the top end power potential. The heads seem to be flowing fine.
No I didn't.
I've done a bunch of supporting modifications and tuning, but the hot and cold side piping was done very well.
I really would like to put a cam in it, but I think the heads are also a restriction. I'm not sure how much I could gain with it, and there aren't a lot of people doing this to a 4.3l vortec v6 so I don't have anything to compare to.
Well, I've improved by 6 tenths in 2 years with only tuning changes.
First run was ~14 psi and second run was at ~17 psi
This winter I'm planning on upgrading the cam and valve springs.
I'm seeing visions of an LS turbocharged S10 in my head right now! Nicely done Bubba!
There's was a guy back home who had a big tire Chevy Luv with a BBC stuffed under the hood that really turned some heads. Little trucks are great for Pro Street and drag racing machines.
I bet with more thought/tuning/tinkering it could 10s slb. Thanks for updating your thread!
Converter > cam
Ive pretty much never seen a cam worth having not affect drivability at all.
But rockers on that thing, ewp and a converter to use that 450wtq (with traction of course) and i bet he could make it run 10s.
I have a 2800-3000 (unknown from previous owner) stall converter already.
Electric Water Pump? I would like this for other reasons, but I don't think it would make that much of a difference in my E.T.
The main reason I think a cam would make a huge difference is because I can't use that 450wtq. That dyno pull was from when I was still learning, so those dyno pulls are with the converter locked and a bit misleading.
At the strip I launch at around 3000 rpm with about 6 psi of boost and within 1 second I'm at 4500rpm so I really don't use that area of the dyno chart. And I'm not at full boost until about 1.5 seconds.
I went back to the dyno at the beginning of September to try and do some tuning and cleaned it up a bunch. I have a couple things left in my bag for this year, so hopefully I can make it out to the track again before the season is over.
