Reliable DD 11 sec car...
Ok, this is my only car and I want it to have good gas milege and drivability, but want it to perform well at the track. This is what the car well have when I'm done.
My question is, will this make mid to high 11's.
1998 Camaro SS LS1 M6
What I have:
Lid
Pro 5.0/ WS6 Store Stick
SPEC 2 Clutch
Ported TB
What I want:
LS6 Intake
Exhaust (LT Headers, ORY, Corsa Catback)
100 rwhp dry shot (stock fuel pump & injectors)
Tune
What do you guys think? Low 12's, High 11's, or Mid 11's?
Advice? Opinions?
Thanks!!
What I have:
Lid
SPEC 2 Clutch
Ported TB
What I want:
LS6 Intake
Tune
Advice? Opinions?
Thanks!!
What I have:
Lid
SPEC 2 Clutch
Ported TB
What I want:
LS6 Intake
Tune
Advice? Opinions?
Thanks!!
What I have:
Lid
SPEC 2 Clutch
Ported TB
What I want:
LS6 Intake
Tune
Advice? Opinions?
Thanks!!
Yes but will it possibly run high 11's with 275 Kumho's?
I can't beleive I sold my 315's.
Originally Posted by Jordan S.
Wont get it on street tires. Especially with a 6 speed.
Tire width doesnt really effect your traction, its more the quality of rubber your running and sidewall height. It is easier to net better times with a 16" 275 sticky tire, than a tire not as sticky sized 17" 315mm. Your engine set-up will no doubt put out 11's, but goodluck with your rear. Even going for 11's once on an M6 is dangerous.
Originally Posted by imslow
12 bolt/9" 4.10's, 26" drag radial.
you'll get it.
you'll get it.
So how about the 10 bolt for now, I like my gears but when I eventually get a 12 bolt I'll go 3.73's. For traction 275/45/17 Nittos.
You mean dangerous as in breaking the 10 bolt, right?
I will get a 12 bolt eventually, but I don't need one right away, because for one my car only has 30 something thousand miles and a new locker for the 10 bolt. Also, I'm going to take it to the track maybe once a year.
you'll need a lot of power to make up for a bad 60' time to hit 11's.
I saw a guy run a high 11, it was like 11.8x on street tires in his LS1 Camaro M6, short shifter, 3.73's or 3.42 (can't remember), LS6 intake, Mid-Length Headers, Y-pipe, and corsa, and a lil 100 dry shot.
but if you want to do it on a street tire then that would be a good recipe i guess.
there's barely any gain from 3.42's to 3.73's so i'd stick w/ the 3.42... and if you want to spray it you'll need a good clutch.
With what you have get a set of Nittos, launch her soft and you should go 11s with out a prob. With your bolt on mods I was low 12s on motor with my 6spd and nittos, my times with only BOLT ON's while not the fastest ever but on 17" SS wheels on all 4 corners was 12.10 at 114 with a 1.83 60ft on the 10 bolt with 3.42 gears.
Dan
Dan
Nitto's with some good driving would get you into the 11's a friend of mine with an LT1 H/C car with 4:10's ran a 11.8 with a six speed. He did go through a couple of rears though.
I think a 9 inch is a better choice from DLS, you never have to worry about it and if somehow you break it they are a pretty easy fix compared to the 12 and the S60. If you had an auto the 12 might be a better choice.
Nine inch, sticky rubber and a 100 shot you should be in the 11's but this is coming from a guy that ran 12.6's with a 400RWHP Z06. I'm hoping to get low 12's with my new car setup
