12.22@115 bolt-on M6 on street tires
My very first pass of the day got me that time. My next 4 passes ended in blown 4th gear shifts. Damn syncros. On 2 of those passes, my 60' and 330' intervals were .03 and .04 respectively better than the 12.22 pass. I would've ended up with a 12.18 or even lower. My 60' ranged from 1.90 to 1.87 all day on the street tires. My raceweight was 3670.
The temp was in the 40s and the da was around -1500'. I haven't broken the rear on the street tires but broke 3 on DRs. My 60' times are better on the street tires and I find it easier to launch with them.
I guess between 5-7 seconds.
I launch anywhere from 2k -2500 rpms. I ride the clutch out a bit to try to get the car going without shocking the rear.
My clutch is the Mcleod dual friction. I've had it for around 3 years with multiple passes on it. I don't really drive the car that much so I can't really say it has alot of miles on the clutch. The car has 143k miles though. I think what impresses me so much is how well the car is running with that many miles on the clock. I think I may have put 25k miles on it in the 5 years I've owned it.
Well there's a big difference in your racing tecnique and mine. my best 60' is 2.04 and I feel like there is a lot of improvement to be had by me. I never warm my tires up as good as you told me. When its done it has to be done right or it won't work right. btw, any suspension?
I have a gtech pro and my best 0-60 is 4.51 so I can improve that by a lot more if I heat'em up enough.
Track prep is just as important as good tires. Maryland International Raceway is probably one of the best prepped tracks around...especially when it's cold outside.
