Yay i get to join the club. From 13.5 to 12.7!
here is the time slip from tonight. i only flashed to 1200 because i didnt know how well i would hook. thats ok. once i get this 2nd gear shift thing worked out and then flash higher im hoping for under 12.5. here is the slip. im car # 300
hmm
mods in sig. haha
ive got full bolt ons or at least very close to. ported intake, 52mm tb, 1.6rr, cc503, ported maf, port matched heads. 373s. baby 2500 stall. lt headers ory and magnaflow cb. madz28 tune.
i think once i get a couple things worked out and get a dyno tune and actually flash at about 1600-1800 ill be in the low 12s. but we will see. this 60' was accomplished by et streets at 18 psi. hooked like a mother!
mods in sig. haha
You get some 373s and you will be VERY happy. i also went from 273s to 373s, however, if you do that u better get some et streets lol. if you do a stall tires and gears you could take close to a second off of your time. you would be mid 12s if it all works right!
LOL . Its like you read my mind . My 3:73's are sitting on the top of my tool box right now . I also installed a p & p throttle , changed the plugs ,wires and deleted the EGR/air . Then It will be tuned . I hope to be posting my 12 second run soon too . Maybe a should get a set of those ARP valve cover bolts ,,,,just in case
PM me your mods. Juice or no juice? I've got a 96Z with Juice. I'm looking for low 11's next time I hit the track. my mods are in my sig. the 12.2 was on a 75 shot with a slipping clutch.
thanks
lowered the time a lil again today altho the mph is the exact same, and was all day today, 107.40 for all my runs today, and that best run the other day? lol. i ran a 12.68 tonight!!! and the DA was 1459 so if you correct for that it would have been a 12.4. oh well.
