Lets build a mid-engine Trans Am - need advice
Here they are a bit wider and the center moved back like my picture.
Here is the bulge moved way back like in Erocs pic. Even this may not be far back enough to enclose the wheel.
What about mounting the engine in the normal fashion right behind the front seats, with a t56 and tranfer case. By your pics this looks like it will put the transfer case behind the rear end. The driveshaft would be pointing back to the front just like it was designed for. Then use a fullsize truck front diff, and spindles with hubs. Then have custom length half shafts and your in business. No worrying about reversing the rotation of anything. Then your would have mid engine, your 6 speed, and IRS. And all of this would be easy to find in a junk yard.
I see what your sayin - and I too had this vision - but - How does he change the gears? I'm no mastermind nor do I have extensive knowledge on the options for alternative shifting, but what are his options to change the gears on the stick if the tranny is above the rear end?
Y'all need to put down that crack pipe.
This is a 35" tall car. I can't just mount the engine 20" higher.
I dont think i understand your ideas on the trailblazer setup. Which way would the balancer be facing? On my last idea the balancer would be facing towards the front of the car.
I think I'm going to keep the AWD option open, but not screw with it right now. I can use 4 C5 spindles as the front and rear are the same. I just need 2 left and 2 right. Then I'll get 4 rear hubs. That way the fronts will have the splined inputs on their back side. Plus it makes the brakes super easy as well. I can run 14" rotors front and rear.
Let me get the car driving with the front mounted transfer case and see how it does, both noise, vibration and heat wise. If I feel the need later on for AWD, I can add the front diff and halfshafts and be on my way. That sounds like a plan.
I'm not sure how to address the drive shaft joints. The one from the trans to the transfer case should be easy, like a stock aluminum driveshaft, just cut much shorter. The other 2-piece shaft could be a problem. I was thinking of something like on the new G8. (excuse the crappy pics, I used a phone camera) From front to back:
Notice it's small diameter and rubber universal joints. I'm sure I'd need to replace those rubber units with regular steel joints due to the angles. The support bearing is pretty small as well. Think that would work?
Is that going to be turning the right direction?
I also need to think about a LSD between the front and rear diffs to aid cornering. Without one, the car may not turn properly.
Here's your motor pic:
Or, get a 1600cc VW engine!
It's an easy fix. I just need to reverse the rotation at the transfer case or at the diff.
