How does oil reach the cylinders?
I hope that sun is not getting to you out there...
Shane
I figured that is how it works, but wnated to hear from others. Seems like cylinder oiling was kind of an afterthought, but I guess it works. Isn't there some engines that actually have nozzles spraying oil up into this area? Trending Topics
Thanks for clearing pressure and supply up for me DeltaT. On another note, do squirters under a valve cover also receive the pressure and supply from the oil pump or are they based more on directing the flow of oil through the heads/valvetrain areas through the squirter?
