Why Cracked Rods?
And i know that they are cracked.
Ive been searching and found in LS1/LS6 Performance
"The LS1 rod is known as a "cracked rod"
because the crank end is fracture split
during the finishing process. A cut is made
to its inside diameter, the rod is then
stressed such that it fractures at the
stress riser. The jagged surface left on
both pieces precisely locates and locks
the rod cap in place once its assembled."
I read it a couple times.
I guess im looking for someone to re-word it. Hopefully then ill get it.
Its things like these id like to understand. tho im getting rid of the LS1..
Thank you.
Unless having a part that was purposely stressed to the point of breaking in your engine.
I for one will never understand how someone said, hey lets snap the rod & put it in a new engine.
I know I'm old, & they claim it's better, but nothing that is purposely stressed that much, is going in anything I pay for!!
The machining is my point also. The % of cost to a set of rods can't be enough to justify breaking.
As mentioned, what the hell were they smoking when someone even thought of that.
HEY, great idea, let's snap the big end in half & stick in a new engine??
i.e. the fracture surface takes some of the lateral load, meaning the rod bolts can then better concentrate their "function" on tensile loads rather than shear loads.
Stubbornness, stupidity or both.
I like my rods unbroken. I have enough blocks in the corner with holes in them.
It's just one of those things, I can't help thinking the words fractured & cap/rod don't belong together in the same sentence????
I know it's modern technology, it's just me, no biggie.
All of the little stuff adds up fast.
tons of people have these.
i won't re-illiterate what was said before but why not? There are NO disadvantages to this method!
They are powder metal anways
Think about what a rod bolt does...when you combust the mixture above the piston, you push the piston down against the pin, in turn the rod, in turn the crank...that puts little to no force on the rod bolt at all.
HOWEVER, when you finish the exhaust stroke, and begin the intake stroke, the piston wants to continue heading upward towards the head...the crank pulls down on the rod cap, in turn the rod bolts, in turn the rod...pin...piston.
People tend to get misconstrued in this regard because more RPM usually means more power...you go to a different cam, it makes torque at a higher RPM, so you rev it to there, power is a function of RPM...so at that higher RPM, you have more power.
Find out what RPM some big power LS1 was at when the rod bolts failed...then rev a stock LS1 just as high just as often...it'll go boom too (if it can rev that high with the stock heads/cam).
The forces involved in pulling a piston back down are the hardest on the rods and rod bolts in most engines.
Worrying about what happened to the material during the cracking process is just a lack of information about the powdered metal, as well as about how it's treated prior to installation in the engine...last time I did a compression test on a similar powdered metal to whats in our rods...I broached it right through the hardened tool steel pads (I made them and hardened them myself) on the compression tester...and last time I tried a tensile test on the same powdered metal...I broke the gripping mechanism on the tensile tester...stock rods are VERY VERY good rods, they just lack the length I wanted in my new engine build, and they lack a good bolt capable of handling high RPM from the factory. If the length works for you, put quality bolts in them, have them checked for all necessary dimensions, and use them (modify them for floating pins if you want to).
