cr help!!! .200"x4.04 equals how many cc's?
ok, im doin a rebuild and need help on figuring my cr! i have a 4.04 bore, 58cc heads, 3.75 stroke (385 ci) and flat top pistons, no valve release, and my piston at tdc is .200 in the hole! so if i could figure out how many cc's .200" with a 4.04 bore is i could use that figure as my valve relief and figure my cr with a certain head gasket thickness. does this make sense? lol!
sound like sbc/lt type build
ur gonna prolly want to run as thin as possible gasket with piston being that deep bore in the hole.
i have always like to kept 0 deck for sbc/lt at least.
and always minimum
+.010 protruding for ls motors
what gasket u plan on running? its not gonna be same as bore of block. has to be bigger.
assuming u were using a theoretical 4.125 bore by .030 compressed gasket: the above engine specs out to around 8.39:1 scr
and always minimum
ok i think im on the right track,
cylinder volume, http://www.online-calculators.co.uk/...ndervolume.php
convert cubis inches to cc's, http://wiki.answers.com/Q/How_many_c...are_in_1000_cc
ok i found this
http://www.csgnetwork.com/compcalc.html
and yea that was my next question, i prolly need to go as thin on a gasket as possible, what the thinest i should go? and yes its a lt build. im plannin on runnin 20+psi of boost,and race gas. im not to familiar with quench!
the above calculator is pretty accurate. same numbers i got. i figure my scr and dcr by hand with sheet of paper and calculator. i also figure rod/stroke ratio, quench, amount to mill heads, dcr if have cam card etc. i havent found online calc. yet that has all those features.
hmm, thanks for the replies, what gasket you recommend? felpro or cometic? also would there be any disadvantage of running the thinnest gasket possible? i just need to figure out my piston to valve!
prolly thnnest mls u can get. bore doesnt really matter as long as its bigger than 4.04. i dont think u will have too many ptv clearance issues with the piston being that far away at tdc. lol
i always keep at .100 minimum for ptv clearance for both valves
.200 is dam way in there. i dont think ive ever heard anyone going with the piston that deep in the bore.
